Question for the early arrival commenters: are you hearing these SQ improvements on both streaming and local file playback?
Yes.
Bob, are you using a plane Jane Cat 6a UTP from router to switch or shielded?I have only used streaming Qobuz/Tidal. Have not tried files yet.
I always suspected you were hearing voices, Bob. Now we know for sure.One area of the sonics that I did not notice until playing for several more hours with only the Switch/card is the MIDRANGE.
Voices especially have an uncanny realism to them. It makes previous listening to voices appear that there was a restriction or an outline of a voice. In real performance there is no restriction to voice when signing. It seems that previously when hearing the restriction around the edges of the voices it made things seemed maybe focused.
NOW, hearing voices is a surreal experience with zero restriction and an openness that I've personally never experience prior. Beguiling!!!
Steve which Ethernet cable are you using from router to switch? UTP or shielded?I always suspected you were hearing voices, Bob. Now we know for sure.
Seriously, I noted the same phenomenon -- voices sound so much more realistic and present it is uncanny. That was the first thing my wife mentioned when she sat down to listen for a while. She also said the stereo sounded better than it ever has and what did I change? All that without prompting, coming from someone whose feelings about stereo equipment (and me) can be summed up as mild bemusement.
Steve Z
I'm using a JCAT Sig Gold cable from the wall to the Switch. I have 15 year old cable coming from the router through the walls to the RJ45 wall receptacle.Bob, are you using a plane Jane Cat 6a UTP from router to switch or shielded?
Steve, It's beyond hearing the voices, I'm seeing the people from where the voice emanateI always suspected you were hearing voices, Bob. Now we know for sure.
Steve Z
I thought about modifying my JCAT SIG Gold to utilize. Id have re- terminate one end to RJ-45, thanks...I'm using a JCAT Sig Gold cable from the wall to the Switch. I have 15 year old cable coming from the router through the walls to the RJ45 wall receptacle.
Too early to tell. The vast majority of what I've played so far has been streaming. And streaming, even 16/44.1 tracks are sounding better than high-res local tracks did pre-Taiko switch/NIC.Question for the early arrival commenters: are you hearing these SQ improvements on both streaming and local file playback?
I strictly use local file playback and I hear big difference in SQ.Question for the early arrival commenters: are you hearing these SQ improvements on both streaming and local file playback?
I recently learned that there are two lengths for DC barrel connectors. “Long” is 11mm and “Short” is 9mm. I just tried my Short 2.5mm and it seems to fit well enough; but I didn’t power it on yet.
Plain UTP CAT6. A good, certified grade of commercial cable from https://www.cablewholesale.com/. Nothing fancy or audiophile. Molded plastic ends.Steve which Ethernet cable are you using from router to switch? UTP or shielded?
I know, I know -- it's like having flashbacks to my mis-spent youth.Steve, It's beyond hearing the voices, I'm seeing the people from where the voice emanate![]()
Thank you for introducing that album. Its an instant love with that album. Would you recommend the original or the remastered version?Listening to “Tanya” from Dexter Gordon’s “One Flight Up.” Such depth to the music and to hear the bass strings vibrate is amazing.
Really enjoying the sound that the new switch and card are producing.
I'll try removing the bracket altogether as short-term solution, I have submitted my address via email for new bracket.Send us your direct address at support@taikoaudio.com and we’ll ship you a replacement bracket. It appears a few are misaligned. Meanwhile you could remove the bracket entirely and use it that way till the replacement arrives.
