@nuwayGreat details, Thank You. Could You please tell what Edgerouter-X model you are using?
UISP EdgeRouter X – Ubiquiti Inc.
Totally agree. I use the same album to demo . My favorite track of his is Sort of Revolution@jelt2359 and @nenon did a great job describing the improvements in musically relevant sound quality with the new Taiko switch and network interface card (NIC). I'm not sure that I can improve on what they wrote, but I'll try to add my own impressions.
Additional words and phases that come to my mind are a sense of increased energy in the room, naturalness and ease, weight and tonal/timbral saturation and texture. Everything seems much more present and visceral -- little details I wasn't fully aware of before are clearer in a very natural, coherent way. No hint of edginess, or rather if any edginess exists it does so as part of the source track and not as system noise. Voices sound so real and present in my room that I've spent several hours just queuing up any and all vocal tracks I could think of just to enjoy having singers present in my room singing directly to me.
Overall, while I had a hard time imagining how an improvement in sound quality was going to manifest itself with the new switch and NIC, what I'm hearing far exceeds any expectations I might have had.
Just one example of many that sound far better than they did even two days ago:
"Trouble's What You're In" by Fink
Kudos once again to Emile and the Taiko team!
Steve Z
The planned FLAC "solution" is not yet implemented. So, for now, the difference between FLAC and WAV should be unchanged.after installing the switch/network card, has anyone have a chance to compare WAV versus FLAC on local files?
Folded outward so that the hole in the plate aligns with the screw hole in the Extreme's chassis. This will prevent the card from tipping up and in part out of the PCI socket.Folding it in what way?
I think that this is only the second time that a server manufacturer has actually built a hi-fi switch from scratch. I could imagine that designing and optimising the firmware/SW/HW ’handshake’ and traffic flow between switch and router could have some great benefits. I would expect the new router to do a lot more along the same lines. I have found that all aspects of the network’s physical layer are what is largely responsible for the eventual music’s presentation. The better the physical layer, the more easily the brain detects subtleties and differences in the amplitude, phase (timing) and frequencies of the 2 sets of soundwaves reaching our ears.Might be against forum rules but I just listed my two each M12 switches and one Duo3 LPS along with 3 Signature Gold JCat switches on AG. I am still having a hard time comprehending that the Switch/card did away with the need of the JCAT switches/PS that I have been so fond of for the last few years. Go figure.
I have only tried and am using the JCAT DUO3 LPS with the new switch. I will switch to the supplied wall wart ps at some point. At the moment I can't get myself to disconnect what's playing but I will just for the knowledge. Although regardless of the outcome I'm waiting for the BPS as my destination set up.So I‘m going to push the boat out on this one!
Power supplies for the new Taiko switch.
Firstly let me state that I have expectation bias. When I encounter an upgrade that worked in 1 instance, I expect it to do the same in other instances. This of course won’t happen in all cases, for example where the item replaced was in fact superior to the replacement.
OK, with that in mind, my experience with every switch I‘ve owned (4) is that the PS plays a major role in the sonic signature of its output. Change the PS and you change the output’s characteristics.
There’s no doubt that the new switch is performing at new sonic quality levels with its supplied power supply. My question is; does it get even better with more expensive power supplies? If the switch is close to the Extreme then the obvious solution is the forthcoming BPS. But if its remote, what effects do LPS power supplies have?
For me network switches have always been a transparent window into the power supply’s sonic attributes. Is that also true with the new Taiko?
No doubt we’ll be hearing soon…………….
BlasphemyAnother tid-bit is that I prefer Roon now with the Switch/card vs. XDMS prior sans Switch/card. Although there is pretty significant up-tick in overall SQ with XDMS/Switch/card vs Roon/Switch/card, which is to be expected.
My switch and upcoming router will sit on the shelf immediately under my Extreme with the intent that both will be powered by the BPSI have only tried and am using the JCAT DUO3 LPS with the new switch. I will switch to the supplied wall wart ps at some point. At the moment I can't get myself to disconnect what's playing but I will just for the knowledge. Although regardless of the outcome I'm waiting for the BPS as my destination set up.
If you power the switch off, it's not going to pass through the signal from the router is it?@Taiko Audio @Christiaan Punter .....has there been a determination yet as to best connection between new router and switch. It was Ethernet initially but now I'm seeing possibly DAC. If DAC will that be supplied with the router
Also to a/b with and without the switch can this be done by just powering the switch on and off or can that cause damage to the new card
I have no idea. Thats why I asked. Probably a dumb question on my partIf you power the switch off, it's not going to pass through the signal from the router is it?
I have only used streaming Qobuz/Tidal. Have not tried files yet.Question for the early arrival commenters: are you hearing these SQ improvements on both streaming and local file playback?
