so the question of the day from me is "when will the routers start to ship?"
previous response was not until after the Munich show
More accurate as in specifically addressing AP “noise”? Yes. I actually have a pretty decent solution already with a low power AP which is powered from one the Router’s USB ports though a small isolation transformer + filter. Making progress!
A question to Emile re length of DAC from router to switch……. Previously you stated that DAC from switch to Extreme should be shortest useable length. Does the same rule apply for DAC from router to switch
Roon gets a LOT better sounding with the Switch/NIC. As it's been said before Roon with the Switch/NIC card can sound better than XDMS without the Switch/NIC.
I was wondering if in this particular case PoE could be a cleaner solution, soundwise and aesthetically?
That'll be an interesting moment if that happens...
I may be talking nonsense, but why not include the AP directly inside the router, with an external antenna?
A low power consuming circuit.
The whole system being powered by the BPS (or an LPS).
For some of us, simple is good. In my particular use case I never try to listen to the stereo when my wife wants to listen to tunes via one of the AV systems using Roon. Our mostly open-plan home just doesn't support doing that. So what I'd like is the ability for her to listen to music via Roon, streaming to a Roon endpoint and using the Extreme as Roon's core, *or*, with as few clicks and adjustments as possible, allow listening via XDMS and the Extreme in the main stereo system.This is a highly simplistic solution and likely isn't as flexible as what you require - it doesnt allow you to do "unpolluted" critical listening while the non-critical system is operating.
Does your wife leave the server a 20% tip?For some of us, simple is good. In my particular use case I never try to listen to the stereo when my wife wants to listen to tunes via one of the AV systems using Roon. Our mostly open-plan home just doesn't support doing that. So what I'd like is the ability for her to listen to music via Roon, streaming to a Roon endpoint and using the Extreme as Roon's core, *or*, with as few clicks and adjustments as possible, allow listening via XDMS and the Extreme in the main stereo system.
Steve Z
Only to my pocketbook!My wife has an Aurender. No Roon conflict, lol. (Wonder how than happened?) But we have the same open plan conflict so it really doesn’t matter I suppose.
Would two Extremes in the same household/LAN be a problem?
If we can get good performance from that we most certainly will do that as a dedicated “audio” AP is absolutely better then routing your home hifi through the router.
Any estimate for the mat silver finish?
I can only wish!
Steve Z
This would involve changing the router's PCB and even modifying the enclosure to allow a connector for the antenna to be added.
Would you consider a new version of the router?
No, the Router has 2 m.2 PCIe slots on board. Adding a cutout for an antenna is a piece of cake as long as we have it ready before we ship, which I’m pretty sure of we will.
This is a highly simplistic solution and likely isn't as flexible as what you require - it doesnt allow you to do "unpolluted" critical listening while the non-critical system is operating. But I thought I would offer it on the off-chance it's helpful.
One potential option is to use a BluOS device that you can switch on and off. For my house i bought an older model for $200. You can connect it to your home via hardwired or wireless speakers. The device will attach wirelessly to your network and will show up as a Roon endpoint. When you do critical listening on your reference system turn the BluOS device off and disable the endpoint (Roon zone) in Roon. That should remove all deleterious impact of having it on the network. When you or your wife would like to listen around your home, turn the BluOS device on and enable the endpoint in Roon. Your non-critical system will have access to your entire library, your streaming services, and will be controlled via the same Roon interface as your reference system.
While I sincerely hope this pans out, this could prove problematic. Roon/RAAT has a history of using broadcast and multicast for discovery, and also moving ports and methods with evolving releases, so getting this right may be tricky, While multicast traffic is theoretically routable between subnets, broadcasts are not, so this may end up being messy. I sure hope to be proven wrong.
But that needs to be confimed to be superior in SQ to the separate AP I believe.
If not you will setup the AP .
The good thing with Tplink 660 hd is that it can be setup without the console or special controler as
it has its own softwere availabe for log in .
For Ubiquity I found an issue to set it as a stand alone device to be just added without controller.
