The last piece of the puzzle is how to power the AP without compromising SQ.
But using a dedicated AP is simply (far) superior to any of the other solutions I tried.
I always try to not not over exaggerate the impact of “upgrades” we launch, but the way I have it running right now, which is one LPS powering the DC Distributor which then powers both the Switch and Router, with the AP (microtik map lite) powered from either a different power grid or battery is simply amazing. I would rate the addition of DC distributor + Router + AP as currently configured, I’m just going to say it, improving things to a larger degree then the Network card and Switch combo. Clarity, dimensionality, purity, naturalness of tone, ink black backgrounds. And this is with Roon (!). XDMS still manages to extract a bit more detail and is a bit clearer still, but it’s really close. This definitely reverts the clock for Roon to pre v1.6 SQ levels, and then some. Which also hints at why “that went wrong”.
As far as the DC distributor goes, I have a very strong preference for the Switch on the default filter and the Router on Alt filter 2, which just matches well with the system/LPS used. By now 6 others have heard this in our system (not counting Christiaan as he heard a previous iteration) and all 6 prefer the exact same settings on all music played (the differences between filters are not subtle btw, it will not be difficult to select your preference which will mainly vary with LPS used, although you can of course use it to alter your system balance if it was not entirely to your taste before).
I understand the desire for convenience, alternative solutions, multiple Roon Endpoints, adding more devices etc, but I cannot imagine you’d want to compromise this new level of SQ once heard. Going back to “just the switch+network card” would require me to not listen to the system for a few weeks to recalibrate as that now suddenly sounds pretty dull. Adding devices, routing more traffic, it all has an impact.
The last thing left to do is to properly filter/power the AP, which nut I’m very confident on we can crack.
