To see if there’s any sound quality difference.
If I don’t hear a difference when I get my unit I will definitely go wired.
I will only use this via wifi so it will not be trying it wired.
mine works just fine via wifiI will only use this via wifi so it will not be trying it wired.
I understand and I am saying that in my system, wifi sounds just fine to mewil is not questioning how it works. He is wondering if there is a sound difference using a wired connection vs wireless, which there could be since you can turn off the wifi radio if you are wired.
Thank you Steve! I tried this setup after your discovery and I also like the sound of Switch=DEFAULT/Router=ALT2. Makes a big difference in my system.Definitely. My thoughts on default/default using with the RGN2004 or the G2504 provided great sound and using the TP adapters allowed me to use either tube at the same gain settings on Horizon and my Lamm preamp.
The overall winner so far in my system is the Valvo G2504 for rectifier and Router (alt2), switch (default)...for where it is now and where it will be in a few more days I'm betting will be my best and final setting. Roon still sounds better but I still find XDMS more to my liking, knowing NSM will right the ship
To me alt2 is Default plus
and alt2 is Default minus
So you lose signal and have to power cycle as well?when I lose signal which has now become very rare, I power cyle the DCD power supply and once I see the routers green lights flickering I remove and reinsert the DAC cable to the NIC. It restores Taiko wifi instantly
I’m sure it does! But we are audiophiles, and we will leave no stone unturned even if it drives us and everyone around us crazy.I understand and I am saying that in my system, wifi sounds just fine to me
Just a quick question.It’s absolutely worthwhile to use a Wi-Fi analyzer app, I have zero issues here, current uptime 15 days:
That was my thought when I get to that situation. Wired from a laptop used to download or rip music.What are people's strategy for copying music files to their Extreme with the new router? With the wifi being pretty slow, just copying one hires album took almost 15 minutes. Are people going to temporarily connect a laptop to the router via a wired connection for file transfer?
I listened yesterday until late into the evening and this is my final configuration. The sound, transparence, amount of detail and the feeling of involvement was unequaled by al1 in any position and alt2 in the switch position The bang for the buck seems to be with alt2 powering the router and default the switch. Of course we all her differently , have different setups and different rooms so of course YMMV
Steve Z
I have that happen once and I ended up doing the same.So you lose signal and have to power cycle as well?
Me too, actually. It's rare, but it happens.
Any update on this?Currently only the TACDA is finalised. That basically is DAC+Analogue output stage on a daughterboard you plug on to the interface board.
