Speed is overrated. It's the silence between the notes that are most important. It's that silence between the notes that contributes to the perception of dynamic accents or those ever so important microdynamics that make the difference between the music being exciting or boring.
Speed = Low levels of treble disortion
Frank
So we go back to the recordings because they are MY reasons for the trade-offs. I can't go around tweaking to make one track or even an entire genre sound perfect to the detriment of the thousands of other songs in my analog, optical and drive library. No single setting can do it all so I've striven for a balance between getting the best out of the best recordings while leaving enough leeway so as not to make songs I love that are badly recorded totally unlistenable. All this so I can spend time doing what I should be doing, sitting my ass down and enjoying it all.
15 ips 2 track tape can be jaw-dropping in so many repects and I would hate to tie it all down to soundstage size.
But how about the size of the instruments themselves? That could and is also associated with Big Sound. This scaling is heavily influenced in my belief by the contrasts mentioned. Why is it that two monitors each with 1" tweeters and 6.5" mid bass drivers with very similar sensitivity and frequency response differ so much in the size of both the stage and what's in it? Add to that the relative sizes of the instruments in it? Why do some line sources suffer from "big mouth syndrome" on closely mic'ed vocals? Why have we all heard full range speakers in the true sense of the word make neat little precise perfectly scaled dioramas out of what one might expect to be enveloping classical works making the presentation sound "small"? Why does one of the little monitors do big vocals and a lilliputian drum kit (this still sounds BIG) while with the same recording on a big system like Steve's X2s, Gary's Genesis 1s and Jim's VR-11s sound life sized?
No wonder the blue light flesh, in our use of 2 phase no fleshing . I know 3 phase is better 2 phase but one 3 phase power supply to a stereo amp is better than two 2 phase like a mono block ? I am not sure, I would like to have a chance to compare !
tony ma
Distortion differences between setups ..
Nope. Gotta do better than that Frank.
One of the problems I am having with 'big sound' is structural damage to the house. Most frequently, having to deal with sucked in ceiling panels, parts of the ceiling falling during loud playback, dust precipitation, broken fluorescent light tubes, etc. I'm constantly rebuilding my ceiling after a Thursday night playback (while my ears continue to ring loudly). There has got to be an alternative to Armstrong grid ceilings!
There's a difference between an Elephant and Godzilla Mark.
I'm not sure about this. I've been thinking about it and listening to larger systems in larger rooms, and I suspect that "big sound," or the illusion of it, has much to do with the room. So "big sound" here...
...has a completely different set or requirements from big sound here...
...where a pair of 6" monitors and a sub can sound absolutely huge. Most of you guys are between the two extremes. If you scale your system properly to your room, you will move the air that needs to be moved, pressurize the space that needs to be pressurized and create the illusion that needs to be created. I don't think it necessarily gets better because you super-size it, unless what you're going for is larger than life.
Tim
