And so am I with my CDP system.Thanks for participating, chop. I remember Harry Pearson was a fan of L'Art du Son.
I though I ordered a complete machine. The stand with motor, rack, spindle and pucks. All I got was the spindle with pucks and a stand to put the spindle in to dry the records. I have my own ultrasonic. I still have a slow motor used to make fishing rods that has been used to spin the records in the past. I was not going to purchase the Kuzma as I figured $1400 for a motor was a lot. The pumps and filter are the real trick to this project.
Just to be crystal clear, I use an Elmasonic P120 for cleaning, pretty much exactly as Don does. The P120 means I can clean 4 at a time.Yes, I agree - the topic of record cleaning is interesting. We are still in the learning and discovery phase.
I don't know if there is logic here or not: if you don't use IPA, you don't need L'Art du Son? L'Art is an additive.
If you rinse the record there should be no surfactant on it. Ilfotol does not bind to vinyl.
If you use a vacuum style machine, you might want to consider AIVS products:
The Audio Beat - Audio Intelligent Vinyl Solutions Record-Cleaning Products
read audio reviews, ratings, and user opinions on audio equipment before you buy an audio systemwww.theaudiobeat.com
The vacuum style machine is just used for drying and applying the L'Art rinse cycle, again as discussed by Don. I prefer the sound of a record rinsed and vacuum dried to one not rinsed and air dried. Its much more convenient as well!
Dealers surprise me. I said I was using a home made motor and stand so he ordered me a spindle and pucks. Well Hello McFly. If I have a homemade unit, I have a spindle and pucks too. I need a real machine. I got this unit in exchange for labor. Not sure the investment. Since I had a prior falling out with this guy, I guess I won't ever see a real machine.
How are you guys rinsing. A spin clean? A second ultrasonic?
Since I had the pump and filter I ran a batch last night. I vacuumed them dry when done.
The tank on the right is for washing/cleaning - the same as I've been using for a while ... The lefthand tank is for rinsing
I ordered a complete kit????? Who said I ordered a spindle and pucks. I got a spindle and pucks. Not what I wanted.If that's all your ordered (spindle and pucks) why are you bothered by what you got? What am I missing here?
(...) I suggest you find another dealer to see if he can help you obtain the RD frame w/ motor. Although you can buy additional spindles, Kuzma does not normally sell the frame+motor seperately. However, Franc offers superb customer service and if you pursue it, I'm confident the situation can be made right.
This is one of 4? threads on your build. Maybe in total 50 pages to sort through.
All forums become somewhat overwhelming to refind information you may want that becomes buried. Sorry I asked.
I just installed this pump. My last one was making funny noises and not flowing enough. This one seems like it'd be weak and pathetic but if it lasts for awhile it's actually really good; flows fast (can drain full tank in moments). I switched to 1/2 lines for it, too. However the fittings it comes with that say they are 1/2 are indeed only 3/8. I have to redo the tape on them later today because overnight I got the tiniest big of water to come through the threads on one. That is partly due to the original being a different type of seal. So far no hose clamps have been necessary except on the ultra sonic that has an odd sized spout that basically requires it (even though it comes with a hose).
