Of course you do, Peter. If nothing else, you are to be commended for your consistency.I prefer the Cessaro based system here. Something about the digital vocals sounds very unnatural.
This is a system video thread about one specific system with a few odd comparison videos thrown in for discussion.
It’s a bit strange that people would bring up a former member and a pair of vintage speakers that no one here owns into the discussion, neither of which has anything to do with Audioquattr’s system. Weird.
The Altec system gets pretty muddy sounding when the piano and orchestra are really going at it. The sounds blend together.
The Cessaro keeps it all separated better but is a bit thin in the body of the instruments...especially the massed strings. Piano is clearer than Altec with orchestra playing hard but it also lacks weight.
I had not heard that effect on vocals from your system videos before. I suppose others might comment.
No worries, Peter. It was probably just another figment of your imagination.
BTW, don't quit your day job.![]()
When I listen to this YouTube example of a piano playing, it really does sound like an actual piano playing it (most systems/speakers, including mine, do not quite get there). I'm not impressed over dynamic range, bass extension or being able to play frequencies above 20K Hz (whether or not I can hear it is another issue), however it only takes a second or two in order to hear/recognise the "realness" in timbre/tone (whatever) that makes these speakers/system stand out, even on YouTube vids.Brahms piano concerto. Second half of the clip captures the essence of the first movement
Interesting, I prefer the Pnoe (breathes easier) slightly.Although I do listen a single driver speaker without a crossover I liked 5 way Cessaro video more.
I didn’t hear it that way, but both systems sound excellent. Pay attention to the violins—the Cessaro setup presents them better IMHO. They’re sharper at the climaxes and during the highest notes, while on the Pnoe system, the violins are more subdued, almost closer to a viola. More importantly, across a broader spectrum, the Pnoe sound seems more midrange-focused, adding a touch of warmth (around 600-800Hz) to everything. That said, the Cessaro setup isn’t flawless either; it can come across as a bit sharp. Ultimately, I think it all boils down to personal preference. For me, the Pnoe sound feels like sitting in the 10th row, while the Cessaro places you right in the conductor’s spot. Maybe that’s because I’m not a fan of single-driver speakers. Again, these observations are based on the videos, and actual listening could completely change my impressions, as it has in the past. I might be quite wrong.Interesting, I prefer the Pnoe (breathes easier) slightly.
Single driver no crossover vs large 5 way
Had another listen, yes I can hear the midrange-focus of the Pnoe, and I can hear what you are saying about the violins being a bit deep? more like violas. I also hear the Cessaro setup sounding a bit sharp (harshness/sharpness affects me like fingernails up a chalk board). I still think that the Pnoe breathes a bit easier, I suspect because there is no crossover so fewer components in the way.I didn’t hear it that way, but both systems sound excellent. Pay attention to the violins—the Cessaro setup presents them better IMHO. They’re sharper at the climaxes and during the highest notes, while on the Pnoe system, the violins are more subdued, almost closer to a viola. More importantly, across a broader spectrum, the Pnoe sound seems more midrange-focused, adding a touch of warmth (around 600-800Hz) to everything. That said, the Cessaro setup isn’t flawless either; it can come across as a bit sharp. Ultimately, I think it all boils down to personal preference. For me, the Pnoe sound feels like sitting in the 10th row, while the Cessaro places you right in the conductor’s spot. Maybe that’s because I’m not a fan of single-driver speakers. Again, these observations are based on the videos, and actual listening could completely change my impressions, as it has in the past. I might be quite wrong.
Here are the videos—give them another listen.
THis is one of the things I like about my speakers is that they are basically augmented single driver speakers and so balance between what I hear in the Cessaro and the Pnoe systems. More mid-centric than the Cessaro but somewhat less so than the Pnoe... a little less mid warmth than the Pnoe and somewhat more than the Cessaro. THere is essentially no crossover except for a cap on the tweeter. My DIY speakers and my previous speakers were both full-range 2-way back loaded horns/TQWTs...again pretty simple in principle.I am certainly no expert but only think/believe that in the terms of music reproduction equipment, less is more. I think that the more tracks, more microphones, more mixing and editing, more components in the amplification stage (especially capacitors and semi-conductors), the less real will be the result.
Mono recordings often sound better than their stereo versions, why? I think it is because of less stuff in the process. Consider the signal is picked up in a single microphone, sent through one simple triode valve amplifier, recorded D2D onto the lacquer, that played back through a good mono cartridge, step up transformers (instead of active MC amplification in a pre-amp), into a low capacitance phono stage (like Ypsilon), there through a flea-watt triode amplifier with attenuators into a single-driver Pnoe speaker(s).
I am probably wrong, but it seems intuitive to me.
My DIY speakers . . . full-range 2-way back loaded horns/TQWTs
No I don’t think ANY speaker can properly convey a symphony orchestra…mine included.Do you feel that your relatively modestly sized DIY two-way loudspeakers can convey the full breadth and power and authority of a symphony orchestra as well as the large and multi-driver Cessaro Zeta? Or in your comparisons are you focusing on other specific sonic attributes?
Will the Cessaro do a better job? Maybe but it depends on the setup and system or it might just make a loud hot mess.
I consider it a significant victory if smaller ensembles and things like solo piano can sound realistic both micro and macro dynamics and tonally. Also the ability to resolve very soft sounds even in the presence of loud sounds is a key to realism.
So, I focus on what I think is actually technically feasible…and I don’t consider realistic symphony playback at home feasible with any system I have ever heard…but a couple of them got pretty good…but were prohibitively expensive for nearly everyone.
I suggest you get a better recording system then because what you say it sounds like live vs. What is heard on the video doesn’t match.It’s amazing the speakers you have made are on par with Pnoe and Cessaro or better. Please post a video of Beethoven 7th
Ps: pnoe is far from a mid centric set up. One of the lest phrases bill and I can relate to in any form of pnoe set up
Thank you. Yes, of course -- I agree that my question was sloppily written.No I don’t think ANY speaker can properly convey a symphony orchestra…mine included.
