I know his amps...I would keep them too and think about how to get the best speaker to go with them...I ag
Remember, it is Marc who is wanting to keep his amps...I personally doubt that these amps will work great with a lot of speakers....and while they should work ok with the 40.2’s, I am not saying they are a match made in heaven.
If Marc’s amps put out about 40+ watts/ch...and will apparently put out 60watts/ch with the GM70 tubes, then they will have enough juice to drive the big Harbeths.
I asked Alex what he thought was a great speaker for 70’s rock, mainly because this is a tough question to answer. Some folks like horns on rock, I personally do not, but what is a great sounding speaker for rock.?
I have heard 40.2’s on several occasions, and they never fail to impress me...on all kinds of music. Are they the best speaker available, heck no...but they are an excellent speaker for the price and I think would give Marc what he is looking for in his size of room. ( and yes, he may have to part with his NAT’s...which also might be part of his problem, because perhaps they lock him down too much to a certain kind of speaker).
Like i stated before, there are a lot of great speakers out there, why not give some of them a try...instead of always bowing at the alter of Zu...![]()
The W13SE from Boenicke, while not really high in Sensitivity, still work well with medium power tubes. I will be using the slightly smaller W11SE in one of my rooms this weekend at the Swiss High End show. The other room will have the 92db Dynamikks Monitor 10SL...both being driven by Aries Cerat SET power.If I can butt in gentleman into this intriguing Thread
I'd consider the Ocellias, Musical Affairs, Boenicke
Frankly any of those I've heard I much prefer to anything Avantgarde
Good Luck
Oh yes Davey --I think it is Mort
BruceD
Good Luck
BruceD
Davey I also am never failing to be impressed by both the 30.1s and 40.2s. They are fantastic and as much for music lovers as they are for audiophiles.I ag
So, you have the horn version of the PAP speakers and not a fullrange driver version (like Tangband or Voxativ)? I saw also there is a version with a Beyma AMT/horn assembly that might be intersting...Davey I also am never failing to be impressed by both the 30.1s and 40.2s. They are fantastic and as much for music lovers as they are for audiophiles.
I also don’t use my horns for rock... my Maggie 20.7s and Harby 40.2s are both much better at that, but I do completely looove my new horns for jazz... I am nothing if not predicable lol
The PureAudioProject open baffle horns with the Line Magnetic 805 amp with 300B drivers and a Microzotl upfront are proving just completely intoxicating... so yes, currently deliriously fuelled by both some jazz and shiraz... happy happy happy cheers to all music loving audio dudes! Marc may your journey bear lasting joy!!! Listen to your instincts and move bravely forwards and Zu will all be fine in the end!
In support of Marc and Zu I have to admit that the soundstage portrayed on the Previn - Planets cut, from vinyl, was exemplary, probably the best I’ve heard in a domestic setting.
I played the same track, from CD rip, on my Duos yesterday and it was flat, with little depth but greater density and oomph. I’m guessing my Duo present it from a podium perspective whilst the Zu from a mid hall perspective.
It’s no wonder many visitors to mine, mainly classical lovers, dislike the Duo.
So the Zu got something right on that cut.
Marc has to get them do that trick every time.
Peter, this was a weird conclusion from Barry, because if anything, classical on my Zus was always found wanting in my old room, and before my tt had the optimal set up it now enjoys.
The music I thought Barry was most going to enjoy, well recorded fusion guitarist Steve Morse on cd, was the presentation he most found frustrating, which led to us reintroducing the acoustic panels.
The Previn on lp, that I hear as a little grey, he was truly impressed by. And his Aqua/SGM/Duos setup is v open and transparent.
This really shows we msybe all share fewer opinions in common than you might guess.
Peter, we all have our journeys.
Mike L recently went thru 6 dacs to get to the Select. I find that perplexing.
Tang and SteveW both have disengaged their subs after expert advice. How is that different from Barry getting me to reintroduce my panels?
SteveW has gone thru any number of Stillpoints, scrapped them all, now is all CS. Thats up for sceptical debate too.
FWIW, yes I did not perceive the phasiness that Barry did. That doesn't make me a bad listener. For all I know, he might be wrong on his analysis.
I'm not so different from loads of audiophiles who have developed their systems, love their achievements, just for another listener to raise doubts.
I've had as many positive reports as negative ones, it's just the former group don't post here.
But, for the record, I have always had reservations on my spkrs, that optimising in a brilliant room has addressed, but also highlighted, and I'm more aware than ever that I'll likely be moving on.
Hoping that lets you into how I feel about things.
