This is good analysis!Either my diagnosis for my original woes was wrong, or my solution was not the best, or things have moved on and previous conclusions are invalid.
Change is progress.It doesn't matter which of these is correct; I'm just glad you're making new progress!
This is pure conjecture on my part. The only time I had objective evidence of power issues was back in London, where my Burmester 948 conditioner registered significant fluctuations in voltage moment to moment. Which pushed me down the balanced transformer route, and subsequently a guest measured my power, and indeed those variations had smoothed out.‘However, things are so different out here in the country, mainly much more stable power coming into the chapel, likely less polluted as well.”
Marc can you tell me how your voltage changes over the day?
Actual voltage say during the evening and fluctuation variance.
Level of noise on the mains in mv
Total power requirement of your system.
Power outages per year approximately.
Thank you
What was wrong with the Burmester? I heard it was quite good.Well, out goes the Westwick 8kVA balanced power transformer, to be replaced by Doepke RCCD and MCBs. Recently I just had the transformer switched off, now it's been physically removed.
After three days of slightly mixed results, the fourth and fifth day are showing a lot of progress.
Critically there's a real boost to image density, and with the stage now being also wider and deeper, I'm likening this to the analogue of greater pixellation.
This feels like a real step change to a much more realistic sound, no hypeing up of any aspect of the frequency balance, just a much more resolute sound in terms of tangibility and substance.
A greater foundation, and more stable presentation.
As my last serious system-wide change, it's proving to be really beneficial.
I also know there's likely more positive changes to be had in the next several weeks.
As things stand, all that's left for me to concentrate on is a CDP service/clock upgrade and mods package, and allocating funds for future tubes and stylii purchases, I have my eye on Audio Note molybdenum 211s.
Ridding myself of the Westwick is the only time I've seriously gone back on a major system-wide change/optimisation, and together with the Burmester 948 conditioner that I used to run that I also fell out of love with, I'm fully aware that these units have been blind alleys for my sound, any positives they brought indeed came with more negatives.
You had us for years hooked on to how you were adding power stuff, cables, isolation, grounding, etc. It will be amazing if the next few years you can have us hooked onto how you are taking out power stuff, cables, isolation, grounding, etcWell, it looks like I'm on a roll of stripping stuff out.
After much ribbing I should divorce from by balanced power transformer, I've gone ahead by replacing with specialist Doepke RCCD and MCBs, to truly amazing effect.
Now a long-term Entreq skeptic in my circle has strongly pushed me to trying my system with the grounding boxes disconnected.
And yes, I'm hearing the benefit.
Not as radical night and day as the Doepkes, but another step closer to reality.
I'm using the newly arrived DG remastered Bruckner's symphonies box set to gauge the changes, and after a couple of hours they're plain to hear.
Hello Marc,divorce from by balanced power transformer,
I can't do this to you guys. The Grand Old Duke of York, marching his 10,000 men to the top of the hill, and then marching them back down again.You had us for years hooked on to how you were adding power stuff, cables, isolation, grounding, etc. It will be amazing if the next few years you can have us hooked onto how you are taking out power stuff, cables, isolation, grounding, etc
Hello Marc,trying my system with the grounding boxes disconnected.
Everything.Hello Marc,
What sonic improvement did you hear from removing the Equi-Tech?
Yes, sorry, I forgot it was not an Equi-Tech product.Everything.
The whole lot.
Nothing Less.
Check post #1968
NB Not MikeL's Equitech, but a UK alternative.
Everything.
The whole lot.
Nothing Less.
Check post #1968
