as far as I know you are not correct.They used it in the Wadax room driving ARC amps are were controlling the volume via RC. The gain settings or amount of output voltage is help match it to the gear being used with it. This is the same in the REFERENCE dac which has an output voltage adjustement 1,2 or 4v the total system volume is controlled with a preamplifier.You can set the gain for 3 output levels for use without a pre amp.
Afaik its not an adjustable volume control
Atlantis and studio are the same in that regard .
So use without a pre amp is kinda limited off course .
( I m quit sure with pre amp the sound is better as well )
i don't have any direct description from Wadax about that. just my own observations about it.can some explain the Akasa cable
is it optical or power or both ?
I heard it without a preamp and Im telling you that room was really freeking good.
it also has a remote control!Yes it sounded good .
It seems like you can control the volume via the streaming app you install on your phone which is cool
• Player using the original app from their preferred streaming service. Switching between streaming services is as simple as changing apps. The use of the native app for each streaming service ensures that Studio • Player does not require frequent updates to stay current, reducing downtime for software maintenance and allowing users to spend more time enjoying their music.
Additionally, this configuration enables any device running a streaming app to function as the controller for Studio • Player. Users can conveniently view artwork and control volume from the comfort of their listening chair.
well that didnt work but it was TAS on youtube
first comments I ve seen on the studio player
The spec voltage is SE or BAL ?as far as I know you are not correct.They used it in the Wadax room driving ARC amps are were controlling the volume via RC. The gain settings or amount of output voltage is help match it to the gear being used with it. This is the same in the REFERENCE dac which has an output voltage adjustement 1,2 or 4v the total system volume is controlled with a preamplifier.
I heard it without a preamp and Im telling you that room was really freeking good. I listened in that room a lot because I think this is a really cool product and I think a lot of people are going to want one. I have a list of those wanting to hear and try it.
not sure but I believe balancedThe spec voltage is SE or BAL ?
there are multiple videos about Munich on the TAS YouTube channel, and then we need a time point on the video where it's mentioned.well that didnt work but it was TAS on youtube
need the precise video and time.
thanks.
847 is the timethe end of Tom Martins report or almost the end is about the Wadax room
Qobuz is supposed to happen this summer.Even if this does not do local files it’s still a good thing for me
in the end I can burn cd,s
even sacd
Tidal has some non red book and mQA and I’ll bet Q buzz is soon.
cost and one box still makes this good I think.
I do feel for ones who have spent big bucks on high end Wadax products it’s tough look and do they feel the transport not doing sacd is tough
