Are you going to pull fiber throughout your house? Other wise it will have FMC's to convert to copper.I like this thread, as our neighborhood will finally be getting AT&T fiber. No ONTs - fiber directly to the home into a fiber based router. So I'd like to know if anyone has looked at fiber input routers from an audio POV. I'm still using the Arris that was recommended here years ago and am pleased with its performance.
So you will still have copper, they are not pulling FOC throughout the house. That is exactly what Verizon and Frontier do .According to the AT&T rep who spoke to us, it’s a fiber run from the street, through the house, to a fiber input router.
I'm building a new house in TX with a dedicated room, fiber will be available(don't know which provider yet), any recommendations for fiber implementation? Sorry if this is a novice question, but I'd rather ask it than make a mistake. ThanksSo you will still have copper, they are not pulling FOC throughout the house. That is exactly what Verizon and Frontier do .
I must be getting slow, as this sounds the opposite of what I tried to say. He said they would be running fiber into the home - no ONT - directly into a router that has fiber input. The router outputs I assume will be all copper, unless it’s something that has at least one fiber output.So you will still have copper, they are not pulling FOC throughout the house. That is exactly what Verizon and Frontier do .
Yep that’s what I was trying to explain. You may hear an improvement.I must be getting slow, as this sounds the opposite of what I tried to say. He said they would be running fiber into the home - no ONT - directly into a router that has fiber input. The router outputs I assume will be all copper, unless it’s something that has at least one fiber output.
Most of the ISP are only fiber to the house.I'm building a new house in TX with a dedicated room, fiber will be available(don't know which provider yet), any recommendations for fiber implementation? Sorry if this is a novice question, but I'd rather ask it than make a mistake. Thanks
Dave
Tony that is a question for ATT.So do we know which devices these guys (in my case, AT&T) are using?
Based on some searching, it looks like the device they typically use is a Humax BGW320. Fiber in, but all copper out. And built in WiFi. Bummer. I suppose the WiFi could be disabled and the device put into passthru mode.Tony that is a question for ATT.
