I'll get the attribution for this little nugget, but it is so apt: "In theory, theory and practice should be the same. In practice, they aren't."
Practice equalling theory over here ...
Massachusetts
Not exactly close but you are welcome to come down to Upstate NY to listen to the Purity Audio Design preamps
Has anyone tried both a CJ GAT and the Doshi Alaap? Would love to know how they compare.
Still searching for the perfect preamp.
I've tried:
1) Pass XP-30: Lovely on classical music, but in my system bass is too thick and slow and there is no air around instruments (probably due to too much warmth).
2) Pass XP-10: Works well overall but a little too thin sounding in upper midrange/treble to keep me satisfied long term.
3) ARC Ref 5: Beautiful sounding and neutral. Maybe because it doesn't have deep bass, but acoustic bass is articulate. Instruments are nicely separated with sense of air around them. Unfortunately it's not transparent enough for my tastes (haven't heard tubes that sound natural on orchestral instruments).
4) Lamm L2 Ref: Beautiful midrange. In my system the bass is not articulate.
5) Ayre KX-R: Outstanding preamp with cleanest signal I've ever heard but very lean in my system and a little cold sounding. Highs were exciting but could get fatiguing after a while.
At this point the only other preamp I can think of is the CR GAT but I know it's tubes and single ended (I prefer balanced due to investment in pricey PAD XLR cables).
Any thoughts?
I had the Atma-Sphere MP-3 dash whatever that had lots of the latest and greatest upgrades including the Teflon caps that I bought brand new. It was nothing more than a hum machine that wouldn't work with any single-ended amp even though I was told by Atma-Sphere that it would.
If it had been connected correctly (which is easy to do), there would have been no hum. But it will hum like the dickens if hooked up incorrectly!
Hi I just scanned this whole thread. As a Wilson Maxx 3 owner, I do know you have to be a little careful on the top end, I can understand your comments on the Ayre (I had it in for a try out also). I went with a Nagra PLL as it seemed to add a drop of warmth....but lost a little resolution/clarity...but a fair trade off. I saw some posts mention room acoustics, I'm about 2/3's done with a Rives project for my room, I can honestly say it's a been a big help..especially in the top end....that Wilson tweeter has never sounded better-warm and so nautural. I might want to try the Ayre KX R again soon...
Another preamp I didn't see mentioned so far is the Aesthetix Callisto...(several versions..signature/eclipse)
On deck:
Doshi Alaap (hopefully in concert with Doshi JHor's, a combination that I've heard 3 times now and enjoyed)
CJ GAT
Ian, is the CJ GAT sounding so good you can't postyour thoughts? - just curious...and ps...I hope it is that good!
Is is VERY good. My initial thoughts (after an hour of warm up) was that it was very warm sounding. Nice meat on the bones, but not very open sounding. Now, after several hours, it's still meaty and packs a punch, but bass is leaner and it sounds more open. Unfortunately, the highs are somewhat grainy. On classical, strings and brass aren't sounding 'beautiful' but rather brash. Not sure why, but I am using adapters (made by Purist Audio Design) to convert my PAD XLR cables on the GAT end to RCA and Jack Tozzi said the extra connection *may* introduce some grain.
Tomorrow I will experiment with changing the tubes (6922's - same as my Lamm M1.2 Ref monos) and see if that helps.
Lots of potential here. Makes me want to beg Jack to lend me the ART monos and see what synergy they would have (and if they would drive the Sashas).
I don't think you really want to rehash everything that happened with this preamp on this forum. Maybe you forgot who I am and all of the hoops you had me go through to hook up your preamp to my system all to no avail including the Jensen transformer box you sent me. It was always hooked up exactly as you told me while you were talking to me over the phone. This had nothing to do with hooking up your preamp "correctly."
How is the GAT coming?
The ARTs are killer with Transparent or MIT!
I picked up the ART monos this morning but unfortunately I don't have a very good SE cable (all my cables are XLR; I was using an adapter to go out of the GAT up until now).
I just turned the system on 10 minutes ago and won't really listen for another half hour but what the first thing I noticed is that there is a lot less gain in these amps compared to my Lamms. I had to crank the volume on the GAT to mid 50's just to get to 85db.
