Although as I pointed out the very good products have 0.1% complex IM distortion (this is way beyond just two tones/frequencies and shows how current measurements are rather restrictive due to having a specific task) and no where like 10% as you may suggest (with the good products and not bad design-implemented), please look at the very last quote where Nelson stated it is quite possible for complex IM to be 0.1%IMD for both negative feedback and zero feedback.You are correct that context is very important, but I maintain that specs are even more important. I'll try to break it out logically:
10 percent IMD might be benign on two frequencies an octave apart, such as a solo flute and it's prominent second harmonic. But on a cymbal crash the low-mid tones added by the IMD will be obvious and irritating to hear. IMD on cymbals and tambourines and spoken voice is especially nasty because it adds low frequencies that are not normally present with those sources. So the obvious conclusion when buying a new amp etc is to look at the specs, and disregard anything with unusually high levels of IMD. Yes, it may not be audible on all sources, but it will certainly be audible on some sources. So it's definitely not a useless spec.
Bear in mind distortion tests from reviews are over the complete frequency range including those I showed for the NAD and ARC, so thnis covers voices and cymbals-etc that you mention.
Anyway this ignores the original discussion point where I raised a cheap negative feedback preamp by NAD that is pretty well designed and also a tube preamp with zero feedback.
Now if you ever listen to a reference tube preamp I think anyone will have a hard time to say that it and a cheap negative feedback preamp sound exactly the same and a lot of those can come down to the descriptions such as resolution, transparency, soundstaging, imaging shown in Jeff's article.
Also consider I showed two such products with negligible measurements.
Distortion was lower than 0.001%, which means it falls into Nelson's category for negligible complex IMD.
Again I understand that but this also ignores my point where I show two totally different products that measure negligible differences for FR and THD (which also reflects negligible IM).The same goes for THD and frequency response. As Ponk said to Mike a few posts back, "So these amps will make warm, sweet speakers with a bass-extension emulating low midrange hump and a harshness-reducing upper midrange dip sound wonderful, then they'll turn right around, without any eq, or any other changes in the system and make dry, treble-forward speakers with a lean bass sound wonderful too?" A coloration that sounds good on some sources may sound bad on others, and have little affect on yet others.
But it is YOU who is stating your 4 parameters as fact for what we hear in audio reproductionAs soon as you show what else there is - being excruciatingly specific! - I'll be glad to update my opinion.
So the onus is also on you, but at least I went as far as finding two products that subjectively are different and also had measurements showing negligible differences, this becomes more interestingly because they are vastly different designs and one is a tube design.
You mentioned a few times in other threads:
However you have not gone into excruciatingly specific detail by showing the correlation between these parameters vs specific perception descriptions which are easy to classify as Jeff has done.There are four parameters that affect audio reproduction: Frequency response, Distortion, Noise, Time-based errors
I have not even gone into psychoacoustics, I am the only one actually presenting hard measurements with their point Ethan that are also backed up by study done by Nelson PassIt sounds like you're talking about psychoacoustics, which is unrelated to gear parameters. Further, and I'm sure I've said it a dozen times this past week alone, what you hear one moment may not be what you hear the next. You could easily like the sound of some recording on someone's system today, but hate it tomorrow. This is inside your head and has nothing to do with what happens inside the gear. So it's not proper to bring up "how we hear" into this discussion. I'm talking about gear parameters, not the foibles of human hearing.
If your talking about that you need to go the next step otherwise your only presenting a hypothesis and that step involves blind listening studies or initially correlating your 4 parameters to specific perceptions and also measurements then we are using different words.
Because that is not psychoacoustics its validation process towards your hypothesis.
Glad of that and you are pretty easy to debate with (even if I do disagree at timesI never took it as an insult, and I call them my four parameters too. But to all who believe there is more to assessing the fidelity of audio gear than these four parameters, please tell us specifically what more there is using quantifiable objective terms. "Resolution, transparency, soundstaging" are all useless because they mean different things to different people, and they also have no metric.
And yeah it is a challenge to take descriptive words relating to perception, thats why you need to be careful on choosing both the words and the listener and also use multiple reviews and measurements they have done, but the real study should be a well designed blind study taking all of this into a test protocol (training on the use of words to hearing and structured framework).
As I say until you go into excrutiating detail (sorry for stealing your words
This is why IMO there will never be a satisfactory resolution to such debates (I mean beyond just you and me), because neither side can or is willing (either due to scope definition or resource or time-effort,etc) to take the necessary steps to move from hypothesis to detailed fact with correlation.
But one thing worked out, I finally broke down to your post into split quotes, so thats something
Cheers
Orb
