... Second, for my vinyl system, I have found that there were two very important features that allow me to get the most out of the 15K+ records I have, including a large number of early stereo from Decca and EMI. This is a phono preamp with variable EQ, allowing both RIAA and different non-RIAA settings. I chose to have Bottlehead build a custom tube phono preamp for me with controls to change the treble rolloff point, bass turnover, and bass shelf, the three variable for vinyl EQ. Because of my ripping project, I needed a phono pre that had balanced outputs
For my system, I also had a switch put in my TT (VPI HRX with Rim Drive and Lyra Skala cartridge) to allow me to change absolute polarity. I find I can hear the correct polarity without great difficulty on my system. I think it helps that I have horn speakers (Avantgarde Duos). I understand that many cone speakers have crossovers that flip polarity so that some of the drivers are out of phase with others. So this makes hearing absolute polarity difficult. However, if you can hear it, having a switch allows you to get closer to the absolute sound. I also have an absolute polarity switch on my Herron 3A (rev.2) preamp, which can be controlled remotely, so it is easy to make split second comparisons.
Third, for my digital recording and playback (I am currently doing a major ripping project - 10,000+ albums and tapes onto 192/24), after a big shootout, I chose the Pacific Microsonics Model Two, along with Pyramix Software and the companion Mykerinos card for my PC, which is a fanless Zalman case with Windows XP Pro and three solid state hard drives. I use Izotope RX2 to declick and denoise. From what I see, I think this would be WBAS. However, it is all very complex pro equipment and software - so there is a long learning curve without help. Since I don't have as much time left as most of you - I had consultants help teach me how to use the equipment and software, including creating presets for the Model Two and macros for the Pyramix and Izotope software.
Fourth, since I have my audio and video systems integrated (my 5.1 is all Avantgarde - a pair of Duos for LR, and 3 Solos for C,LR,RR and a Velodyne DD18 sub run from a Conrad Johnson MET-1), I share the Duos and sub with my 2 channel system running from my Herron 3A. Rather than switching interconnects when moving from audio to video, I had a custom switch built by Scott Rust - whom I recommended to Steve Williams - which allows me to change configurations by a wired remote from my listening chair.
Thanks, Larry
