Thanks guys. It's good to be back.
A few of other WBAS vinyl components.
First, a good industrial strength record cleaning machine. I have used VPI machines ever since they first came out 25+ years ago. However, next week I will be trying out the Audio Desk Systeme Ultrasonic Record Cleaner. The price at close to $4K is not for the faint of heart. We'll see how it works.
Second, another important accessory is a warp remover. I use the Air Tight Disk Flattener - a heavy duty device that puts records through a 4 hour heating and cooling cycle - great most all warps, like dish warps and even some edge warps. It runs slightly under $2K.
Finally, is a good strobe to accurately measure turntable speed. I use a Monarch PT99 which reads up to 3 decimal places and is an industrial product. At less than $200 it is priced comparably to the audiophile products that only read to 1 decimal point accuracy. You place a small piece of reflective adhesive tape (supplied) on the side of the platter and device measures the rotational speed.
-----Just WoW!
To tune my system, I have found Jim Smith's new book and video set "Get Better Sound" extremely useful. I even bought a laser tape measure to precisely set the distances to my speakers and followed his advice - which generally costs nothing to implement to fine tune my system. It is currently on sale for about $50. He uses some commonly available CD's to check your system. For example one cut of the Chieftain's 'Tears of Stone" CD has a distant chime. If your speakers are even as much as an inch different in distance from you, the chime will move from its correct position - near the right speaker to the middle or even left side of the listening field. I interacted first with Jim almost a decade ago when he was the US distributor of Avantgarde. He was very helpful, even though I had purchased my Duos used. You may not agree with everything he says, but I find Jim to be practical and thought provoking.
Thanks, Larry
-----Excellent CD Larry.
----.----Click on it ^ for sound samples.
