Zenwave D4 or Audience AU24 SX ! !
rgmd11
150
113
175
Hello,
I have recently had a few cables on loan from my local dealer from Synergistic Research (mid to high range and a Stealth "Air King"),i did not care for the former but the Air King did sound very very good,but if anything the treble was a little too bright and splashy and the Mids a little to recessed,
Does anyone have direct experience of using the D4 and AU24 SX cables ! !,i can get them for pretty much the same price,these are for use between my Lumin D1 and Gryphon 120
Also loaned at the same time from my dealer was a Synergistic Research Powercell 8 SE UEF which made a huge difference,does anyone have recommendations for something similar ! !
Thank you and much appreciated for any answers / advice
Al M.
8,802
4,552
1,213
Greater Boston
DaveC
3,899
2,142
495
I'd recommend demoing both at the same time, that should make things clear.
Same with power distribution, my SurgeX with NCF receptacles and Furutech DPS-4 Power Cable with FI-50 NCF plugs is available for demo.
I think a demo in your own system for whatever you're considering is a very good idea.
