Rockport Orions with a subwoofer?
IMO and IME it very much depends on your room size / dimensions and speaker type. The Arrakis' woofers, if memory serves act almost as subs, I think they cross around 100Hz. Also, Arnie's room was quite large so placement was not as critical as in most rooms with room modes. Putting subs right next to woofers in mains in most rooms is not the most ideal positioning as you're exacerbating the woofers' bass from essentially the same location.
Very fair point on rooms. As for placement of subs next to mains, that is good to know. I have almost never had our sub next to the main but in the opposite corner. Mainly due to living room configuration.
That said, I admit I was actually thinking dual subs, 1 near/slightly behind each speaker...so glad to know about your point here. Will make sure to think about placement very carefully if we go thru the trouble of a major upgrade of the sub to the next level.
Reactions: John T and sbo6
I have listened to Arnie's system twice over the years. Amazing system and room. The integration of this six pack of subs with the Rockport Arrakis is impeccable, completely seamless. Some people recommend the dual subs besides the main speakers for time alignment sake, if the room has enough space.
Reactions: John T
The integration of subs is not overly complex, if you know what you're doing (by ear doesn't cut it IME). In general, a larger room makes the process less complex (assuming fewer and less severe room modes). In Arnie's case, with the 6 - pack and also with his previous subs, they both integrated seamlessly. Are the 6 pack better subs (and 3x as many as previously)? Sure. Also, setting the XO point so low makes it that much easier.
WRT subs behind the mains, I have 2 of 4 set up this way primarily for corner loading and to minimize room modes. But putting the subs right next to the mains (like Rel recommends) is to be frank, idiotic, again unless you have a large room, which most of us don't (even then it's questionable if it's the optimal positioning). I think most people do it because it looks cool. See Toole's book for more details.
Reactions: John T
Given the fact that Arnie (of Arrakis, REL 6-pack fame) found that set to 24hz or 27hz, the 6-pack was a big plus for his Arrakis, I think it is safe to say if you like what the 6-pack is doing for you now...then you owe it yourself to start with the full 6-pack if you ever drop in the Lyras.
Lloyd your most likely spot on starting with the 6 pack. I have had them now for almost 2 years. This January it will be 24 months. It would be difficult to enjoy listening now without them. The only small obstacle is to somehow obtain the Lyra's!! Wouldn't that be nice. I couldn't agree more with @sbo6 regarding room size. As I have previously shared my room is 30' X 26' X 26'H. A frame 9/12 pitch, with an open loft. We're talking somewhere in the 15K-20K cubic feet range. This open concept needs subs. Placement is an entirely other different interesting aspect. I know guys who do setups for Rockports with Subs and they like the subs (regardless of brands) parallel with the Lyra's fronts. I had them that way for quite some time but I now have them 7" recessed back from the fronts. Every room is different and no right or wrong. Just be patient and let your ears be the guide...
Reactions: Alpha121
I would only recommend subs with Lyras depending upon choice of music. Lyra is very different animal from Arrakis. Acoustic jazz and small group format better without. Full orchestra yes
Reactions: sbo6
If any subs are integrated appropriately with any speakers why would the genre of music matter?
Because nothing is free. Subs help reproduce the sensation of a full orchestra in front of you. They also help the concussive impact of various instruments. However, no matter how perfect the dial the midrange in particular suffers a bit. So, whether the trade off is worth it or not depends upon what you are listening to. It also matters how sensitive you are to this and what your equipment choices are. If you don’t hear any issues by all means go for it. With Rockports whose strength is transparency and timbral accuracy you will notice it more. The people who buy them tend to be in this camp. The creators of them dont make subs or recommend them. Wilson’s forte is scale and impact. Subs accentuate this. People who buy them tend to like subs. Their creators make subs and do recommend them. It’s just a question of personal taste. I prefer my Orions without them but if I had a huge room and listened to full orchestra or frequently blasted some Zep then I’d have a pair handy for that when I did it. Just my thoughts. Others will feel differently
Back to the topic of this thread:
Has anyone paired subwoofers with the Orion in a large room, and if so, which ones and how is the result?
I have heard the Orion paired with a couple of dual 12" subs (custom made) in a large room. Tried first without the subs, and for me, they lacked extension and visceral impact. With the subs they sounded great and integrated well.
I have purchased a pair of Orion, for my large room, that I am going to pair with two Perlisten D215s subs. I should hopefully receive my pair of Orion by June.
That is very interesting.
I too, have narrowed it down to Perlisten, and am debating which model.
Reactions: sbo6 and John T
Who ever says or thinks Rockport doesn't recommend subwoofers is misinformed..
Reactions: Alpha121
IMO I don't think any speaker company doesn't recommend implementing subs, even those that don't make sub products. But there's a perception that some speakers are so elite that subs dilute the sonic benefits of the mains. How, if remotely even true that outweighs the detriments of sub(s)'room mode management is comical.
Reactions: John T
Absolutely, I have had conversations with Josh, they are not anti-sub. There main goal is for their speakers to sound there very best in any and all applications. And as you reference I would think any and most speaker companies would want the same...
Reactions: sbo6
I have had the same discussion with Andy and Josh a number of years ago. We discussed subs with their speakers and they kindly provided high level guidance that it could work providing the subs were designed and implemented really well.
Reactions: sbo6
Must be an incredible experience in your room!
I have had multiple conversations with Josh and John over the years about this very subject. They don’t generally recommend it. The first conversation on the subject was when they began working on the Orion project (a joint project between Andy and Josh) years ago.The last conversation I had with them on this subject took place at Rockport in Maine in 2024. Me, Josh and John sitting in their listening room talking about speaker design philosophy. A two hour conversation. Direct first person communication. The opposite of misinformed. Now If you tell them you want to use subs they will support you. They are not in the business of arguing with customers who want them (or dealers who sell them) and they are not dogmatic about it. If you (like I) are just having a private in depth conversation with them on the subject they will tell you that they don’t recommended it. I’m always trying to get information about future products and just recently I put out the idea of subs or seperate bass towers for a super speaker but I didn’t get the idea they were interested in either. They might change their minds if they can over come their objections. Who knows? Right now they do not recommended it subs.
Apparently I became "confused" speaking with Josh last week during our hour long conversation. One of several last year and this one, along with John. BTW both great people to speak with. Perhaps he or I wasn't specific enough? Or perhaps the client in Mexico City that Josh told me about with Lyra's and a 6 pack array of Carbon Special's was also a figment of my imagination. The obvious was mentioned regarding set-up. Getting the Lyra's situated first. That's when things become murky, and me talking about the cubic feet, would one consider a pair of 31's or 32's vs the 6 pack array of Carbon Specials. If memory serves me right that's when the figment of my imagination erupted and me "thinking" that Josh mentioned the client in Mexico City. Along with Josh saying go with the 6 pack of Carbon Specials, especially the fact that you have them. I love a good Mystery! I also wish I had the unlimited scratch to implement the Lyra's now! Selling my 6 Carbon Specials will help. BTW, it's a good thing this has come to my attention because I was go to speak with the imaginary figure in Mexico City...
