In concept, a fair point. But I cannot afford two Wilson Audio Master Subsonics; therefore a fortiori I cannot afford three or four Wilson Audio Master Subsonics.
Are you planning to set up a night club for rave parties for old audiophiles?
1) I don’t think big drivers stuffed into small boxes and using EQ driven by kilowatts of Class D plate amps is the correct, organic and natural way to generate sub-20Hz infrasonic energy.
2) I believe in line sources, or systems which are effectively line sources, at all frequencies. I don’t believe in generating low frequencies from boxes just a little bit above the floor.
Totally with you Ron. I heard the mighty Arrakis...and i remember thinking they are probably at the top of the pile for me today...and while it would some real quality/power to provide an even greater foundation underneath them...i would still do it with superb subs.No, there are no subwoofers at Gryphon Audio. It never would have occurred to me to even consider subwoofers, as the eight 8” drivers of the Pendragon woofer tower have the same surface area as two and one-quarter 15” drivers.
But then I heard MikeL’s four 15” drivers X 2, Audioquattr’s 16” + 16” + 18” drivers X 2, and a friend’s RELs on top of subwoofer towers, and until I read about Arnie’s (in Texas) dual subwoofers with Rockport Arrakis, and Wilson Master Chronosonics with Master Subsonics.
The closet analogue (no pun intended) would be a friend’s RELs on top of subwoofer towers. The RELs provided a kind of low frequency foundation to the whole sound-stage that I found desirable. Interestingly, this friend’s room, like my room, has large openings on each side wall. I theorize that a listening room with large openings results in the room having a different ability to absorb (and release) low frequency information than is the case with a sealed room.
Similar to the way it turns out that there is phase information above 18 kHz which we don’t hear directly but somehow perceive (per Sean Casey), I think there is infrasonic information below 20 Hz which we might not hear directly but which somehow contributes to a more believable sonic experience.
MikeL may be able to elaborate on this, as his system is down like only -3dB at 10 Hz, or something wild like that.
1. And yet I doubt in millions of years of listening could you pick the difference between them by ear alone. We're talking about frequencies that are mostly felt, not heard by very many humans as our ears simply are very limited in these ranges. And I'd argue the Funks are much more organic because they rely on driver and box coercion for resolution as opposed to faulty (presumptuously wrong) feedback in this range. Frankly trying to generate frequencies this low, extremely powerful class D amps and long throw woofers are the best way because physics dictate the fact. That's why the MM7 uses exactly that.
2. Low frequencies do not operates nor care about how you feel for line sources. They're too long to abide by any line source rule. You'd need subwoofers that were literally 27.5 foot to even start to create a line source at 10hz. Otherwise they're just stacked, and not acting as a line source at all anymore than a single sub sitting by itself. The 10hz wavelength is 109.677 feet long. This is why subwoofer frequencies are omni-directional, because even if they subwoofer wasn't 27.5 foot itself, the baffle would need to be to prevent the omni-direction.
A set of ML Statements E2 for sale on Audiogon right now, use the sub towersWhat do you mean by “faulty (presumptuously wrong) feedback in this range” [with the Master Subsonics]?
So you think Wilson Audio designed the Thor and Subsonic the way they did merely to look impressive and cost a lot, and that they achieve nothing more than a single driver in a tight box on the floor would accomplish?
I tried them with VTL on the main towers, and it was fantastic !I love the E2!
But I wonder (I doubt) ML can support that product today if drivers are dry or seals are cracking, etc. I would be concerned about the midbass coupler drivers, for example.
But If I didn’t have my speakers I likely would buy that system!
ML Statement E2 or Wilson Alexia 2 (or any other similarly priced conventional box speaker) for the same price? I know which I would take!
LL21 should buy these MLs!
You should love the Eclipse.. I have a friend locally with the Mapleknoll... he is not very technical and I do have to go to his place to fiddle with his table from time to time.. mainly because of long periods of dormancy. When it runs it is a great performer.I tried them with VTL on the main towers, and it was fantastic !
Not Siegfrieds but the previous Wotans, the Siegfrieds are more resolving, and easier to maintain, the Wotans where brute beasts ! I think the mid bass and bass drivers are paper cones made by Danish Scanspeak, and very durable. I would be surprised if Martin Logan did not have a stock of them, they where not
crazy expensive drivers. When i bought the E2 sub towers a few years ago, one
of the specialy made large spikes was missing. Martin Logan had it in stock,
they are still a solid company, but i miss Gayle Sanders, he was a innovator !
I followed your lead and bought Aesthetix Io Eclipse with second power supply, my first serious tube purchase, can’t wait to hear what all the fuss is about !
It is a good TT once you figure out a steady clean air supply, and a goodYou should love the Eclipse.. I have a friend locally with the Mapleknoll... he is not very technical and I do have to go to his place to fiddle with his table from time to time.. mainly because of long periods of dormancy. When it runs it is a great performer.
For now Benz LP-S and Benz TR .The TR is not ideal, as it is very low outputCongratulations on the Io Eclipse with two power supplies! That is exactly what I have on order.
What cartridge do you plan to use?
I’m hoping it’s listenable with stock tubes on a solid foundation.Lagonda, for panel applications, which require large backward layering, air, stage, slam, there is hardly anything I would prefer to aesthetix and Allnic. They also as density to panels. Just on aesthetix, it is crucial to replace the tubes and also rewire it. I don't know the details of what to use. Kcin would have tried tubes as would UHA's Greg baron, do you can ask them. Greg would also suggest shun mooking each of the three boxes .
table for upgrading. The air bearing can handle a lot of weight with no problem,
i’m using a combination of 60 lbs lead and 60 lbs steel platters, managed
by Phoenix techs controller and tach. I also have a SME 3012R arm on a
Micro Seiki type outrigger, it is very stable combination.
Do you have a extra phono input on your Eclipse ? If yes, can you do separate
loading on it ? I have never heard the Eclipse and bought mine on you, Ron and Keds positive feedback only !
