Analog Magik
Marcus
560
555
1,155
Maybe there’s something about these calibration procedures but how do you explain the good old analogue oscilloscope confirmed Adjust+ measurements not Analog Magik’s?
Reactions: tima
bazelio
2,494
1,748
345
California
What was cartridge voltage output, the gain of the phono stage used, and the noise floor of the scope?
In this case the more likely answer is that Analog Magik is making assumptions in software that aren't correct, which are probably related to the sound card or the calibration of the sound card in use. I'd still like to know which sound card was used and if/how it was calibrated.
Marcus
560
555
1,155
Don’t think this is relevant in the context of diametrically opposite results between two measuring methods but as I said, will try get more info and will come back if I get any relevant or at least interesting information. Was hoping someone else also did such comparisons...
Reactions: leftside
bazelio
2,494
1,748
345
California
It may or may not be relevant, but it can be difficult to measure very small voltages accurately with old analog scopes. The induced crosstalk signal is at a low RMS voltage. In general, I'm simply interested in trying to root cause the problem here and understanding the variables in play only helps. There are two broad categories of possibility: user error and tool error. I'd like to get Analog Magik myself but don't really want to spend money on it while this issue is not understood.
Reactions: leftside
leftside
173
211
150
Probably not but I wouldn’t feel comfortable knowing all others easily achieve 33dB.
i don't think a single cart has ever measured that high with AM. As mentioned earlier, it's rare to see a cart measure over 30 with AM, even though Vienna has seen an AM measurement of over 31 with some of his carts. I'm quite confident my Benz is fine, especially as it came back from Soundsmith fairly recently.
Reactions: Marcus and bazelio
leftside
173
211
150
I emailed Richard Mak and let him know about this thread. Perhaps he will be kind enough to comment.
Reactions: bazelio
Marcus
560
555
1,155
Sorry, didn’t see you measured with the AM. I absolutely believe results you got were as you say, but with the Adjust+ they are closer to some manufactures specifications. This is not important IMO. Different measurement methods, different results, nothing new. Obviously AM is different from Adjust+ also in this.
This is a photo of a tech spec you get with the LP-S. Have seen only one (among many) that has achieved 35dB...
Reactions: leftside
tony22
591
261
153
63
On Adjust+ I remember getting in the range of 35 dB (IIRC actually a bit better) on my LP-S.
edwyun
38
32
83
44
My A+ and AM are not that much different. The A+ measurements and graph seem to be inconclusive as to phase so I set Azimuth to match levels as close as possible and lowest mono differential (eg -2 in the chart below)
Reactions: bazelio
edwyun
38
32
83
44
On AM, the channel difference seems greater than on A+, all the time. Perhaps due to differences in software algorithms. These get you close but still need to cinfirm by ear.
leftside
173
211
150
edwyun
38
32
83
44
If you adjust the azimuth to get a closer/better reading with AM does the sound improve?
In a prior setup (VPI Scout 2 with Dyna XX2.2) yes, AM was very helpful to adjust for improved sound. I am installing the Dyna on my VPI Prime and getting there.
leftside
173
211
150
I found the same. It's a journey :) You are on a very similar path to me. I started out with a ScoutMaster/Dynavector and then slowly migrated/upgraded to a Prime Signature/Benz. I find AM invaluable now whenever I change anything with the setup.
edwyun
38
32
83
44
Agreed. A+ and AM are great tools. Even helped "see" and remedy the vibration/hum from the 300 rpm motor pods. The 600 rpm motor pod is actually quieter. Go figure.
edwyun
38
32
83
44
And just for comparison, here is the same Dyna XX2.2 on the Scout 2 when it was dialied in. I wouldnt worry too much about actual numbers.
Reactions: bazelio
tima
5,865
6,937
1,400
the Upper Midwest
running the same cartridge with the same settings,each of the 33.33 and 45 rpm test vinyls will give me different results as you will see in the attached photos
Hmmm ... interesting experiment. I wonder how many people with AM have done that comparison. It would make me want to try a third test record.
Did Richard Mak have any comment on those differences?
Vienna
Dear Tim
Richard told me that its normal and expected that 45rpm will yield better results comparing to the 33rpm.
What he cannot explain is the reason of obtaining different results by two different 33rpm or 45rpm test vinyls of AM.
edwyun
38
32
83
44
Dear Tim
On AM, I get different readings on 33 versus 45 (better) as well. Probably due to the software algorithms. Perhaps it will be addressed in version 2 (when it cones out).
Reactions: Vienna
