Don’t think this is relevant in the context of diametrically opposite results between two measuring methods but as I said, will try get more info and will come back if I get any relevant or at least interesting information. Was hoping someone else also did such comparisons...What was cartridge voltage output, the gain of the phono stage used, and the noise floor of the scope?
Probably not but I wouldn’t feel comfortable knowing all others easily achieve 33dB.
If you adjust the azimuth to get a closer/better reading with AM does the sound improve?On AM, the channel difference seems greater than on A+, all the time. Perhaps due to differences in software algorithms. These get you close but still need to cinfirm by ear.
View attachment 61670View attachment 61671
I found the same. It's a journeyIn a prior setup (VPI Scout 2 with Dyna XX2.2) yes, AM was very helpful to adjust for improved sound. I am installing the Dyna on my VPI Prime and getting there.
running the same cartridge with the same settings,each of the 33.33 and 45 rpm test vinyls will give me different results as you will see in the attached photos
Hmmm ... interesting experiment. I wonder how many people with AM have done that comparison. It would make me want to try a third test record.
Did Richard Mak have any comment on those differences?
Dear Tim
Richard told me that its normal and expected that 45rpm will yield better results comparing to the 33rpm.
What he cannot explain is the reason of obtaining different results by two different 33rpm or 45rpm test vinyls of AM.
