Loving the Nagra...ooh, I kinda wish I was into tape.
What are those panels on the flr?
That’s really magic. Very slick, looks fabulous, congratulations. I have toyed with the idea of going with the Nenuphars instead of the Harbeth 40.2s. How is it all sounding? Musically is it doing it all for you?I had to find a new destination for my old and faithful SME V. I therefore decided to build a small full analogue system in a tiny den upstairs. My work schedule does not give me a lot of time for listening to music during the week. Firing up the main system requires several hours of warm up and leaving the big Krells or the Tenor Audio on is not an option. The main system works mainly during the weekend. I therefore wanted having a system that could reach its optimal performance in a matter of minutes. Single ended triode was definitely the path to follow.
I wanted to fundamentally depart from the sound from the main system. I was therefore looking for relatively high efficiency loudspeakers that would be suitable for a near field listening experience in a tiny listening room. I chose the Cube Audio Bliss C. It has a single full range driver that provides an astonishing single point source sound. I hooked to each loudspeaker an Entreq Olympus Ten grounding box.
The integrated amplifier is a Line Magnetic LM-805IA. I swapped all the stock tubes against high quality ones: a NOS RCA Western Electric 6SL7GT/VT 229 from the US Signal Corps, a pair of Psvane CV181/6SN7, a pair of 300B RK Anniversary Edition from KR Audio and a pair of Psvane 805A Acme.
The turntable is a heavily upgraded Thorens TD 124/II with mods from Schopper, HAT, Audio Silente, Retrotone and Woodsong. I has a separate power supply. I mounted a Lyra Skala cartridge which works very well with the SME V. As the listening room has a suspended floor, I opted for a wall mount console. The phono stage is the tiny Octave EQ2. This is a fantastic little Swiss Army knife that works perfectly with the Lyra Skala.
The second source had to be a compact tape deck. The obvious choice was a Nagra IVS with its QGB extension module. I found one in pristine condition. It had been been fully checked and calibrated by Giorgio Foschi and my local tech had also had a look at it.
The acoustic treatment is limited to three thick tatami mats on the floor and three Crystal diffusers from SMT.
Just pure pleasure and fun.
That’s great. The more music thing is the ideal. It just looks like a great space and a lovely system to relax and listen a lot to.It is a totally different experience than with the main system: near field listening position, single point sources and singled ended triode. It is highly satisfying as this system delivers a beautiful and very precise soundstage. The Cube Audio Bliss loudspeakers are specifically designed for small rooms. I did test them in the little barn before bringing them upstairs. Though they sounded great in the main room, they are sounding much better in the tiny den. This system allows me to listen to more music which was my ultimate goal.
Congrats Denis!
I see you have my all-favourite album waiting for my next visit
dB A with a calibrated SPL meter.Nice looking space! I'm curious how you measured your ambient db level to get 36db? Was it type A or C?
Congrats on the improved soundIn a separate post, I covered the upgrade of the Transfiguration Proteus cartridge into a Transfiguration Proteus D with a diamond cantilever.
[link]https://www.whatsbestforum.com/thre...-diamond-cantilever.35482/#post-823651[/link]
Revisiting the interconnect cables of the phono setup has brought a substantial improvement.
As the Thrax Libra preamp is a full balanced design, I replaced the RCA Elpispandora Red Miracle interconnect cables by Elpispandora Daphne Light XLR cables (the same as for the Merging Technologies setup).
The phono cables between the Allnic phono stage and the Consolidated Audio SUT have been replaced by the brand new top of the range Sculpture A from Ana Mighty Sound. These cables are inspired by the phono cables used in the top of the range Phasemation EA-2000 phono stage which I had the chance to listen in my system.
I never liked the Brinkmann record clamp which I find cumbersome to manipulate. Brinkmann and AMG have identical screw down record clamp systems. The record clamp of the AMG Viella Forte is larger with better bearings and a shape that eases the screw down process.
And finally, some additional acoustic treatment in the Little Barn.
For several years, I have been very pleased with the rather stealthy acoustic treatment provided by several large acrylic SMT panels.
However, there was a specific frequency range between 160 and 400 Hz that could not be sufficiently tamed.
The distributor of Art Novion acoustic treatment solutions spent an entire afternoon taking measurements of my listening room. He proposed installing 6 absorbing panels on the ceiling above the listening position as well installing 4 tuneable absorbing panels behind the listening position. The tuneable absorbing panels can be set up to work within specific frequency ranges (in my case between 125 and 800 Hz).
Preliminary tests with the tuneable absorbing panels were quite convincing when I played some cello music. The Cello is the instrument closer to the human voice and covers a range between 65 and 660 Hz.
I installed the panels myself which was a nice DIY challenge.
With their hand made bricks, the walls do not offer a flat surface. Fixing wooden studs on the walls allowed adjusting the placement of the panels on a flat plane.
Gluing the other 6 absorbing panels on the cathedral ceiling at about 15 foot high in the air was quite an experience. Luckily, the old beams that a crossing the room just below the ceiling helped securing the ladder and also gave me some additional safety while manoeuvring in the air.
Visually, the treatment is not too intrusive. Sonically, the improvement is worth every penny and the effort I put in installing the panels myself.
My only regret: I should have implemented this many years ago.
