May i ask you how could you link 2 switchs together? Using SFP port isn’t it? And which cable are you using to link them up? Melco will go to your endpoint (streamer/dac)?
Yes, the two switches linked by optical fiber with the Melco S100 downstream, going into the server.May i ask you how could you link 2 switchs together? Using SFP port isn’t it? And which cable are you using to link them up? Melco will go to your endpoint (streamer/dac)?
Hi Abyss Man,
I’m also having a bit of a logic crisis, when you say that the JSSG360 screened cable picks up RFI/EMI and the unscreened doesn’t? could it be that the screen wasn’t fully isolated?
In all honesty, I cannot say buddy but its still in my switches and will remain there. I like them a lot. They had brought a slight oomph in the bass region and the mids were smoother when I installed them. Now I cannot really tell anymore cause the Gaia is there and I don't know which is doing what but I love it.Hey Abyss Man - how did the replacement cable relative to the silver upgrade version end up? What differences do you reckon the change made and was it worthwhile for you? Thanks!
Does anyone have an explanation of why a cable SPECIFICALLY designed to avoid RFI pick-up would perform far worse with regard to RFI compared to the same cable with no protection? The whole point of JSSG360 is enhanced screening to prevent the cable acting as an antenna, so what could have happened in this case where JSSG360 apparently injected noise into the cable?Hi,
Think you got confused, the one sent with the Jess shielding didn’t work out for me cause there was RFI pick up. Steven sent me one without the JSS shielding and it was ok, no RFI pick up.
As for the cable make check post #33. It’s still silver btw only thing it’s solid core and thicker awg.
Hi Blackmorec,Does anyone have an explanation of why a cable SPECIFICALLY designed to avoid RFI pick-up would perform far worse with regard to RFI compared to the same cable with no protection? The whole point of JSSG360 is enhanced screening to prevent the cable acting as an antenna, so what could have happened in this case where JSSG360 apparently injected noise into the cable?
