All Sablon interconnects share the same extremely transparent conductor with my non-invasive ‘Roswell’ shielding and low impedance grounding. Geometries are optimised according to single ended and balanced iterations, given their different design requirements.
The Reserva RCA interconnect benefitted from an enhanced geometry for 2019 and is available with a choice of either KLEI Pure silver or Bocchino platinum rca plugs. I won’t beat around the bush here - it is the latter version that you will be wanting.
As well as superb metallurgy, the Bocchino further benefits from solder-free set screw termination which also allows for Furutech Nano Liquid contact enhancer to be applied. This cable has been tested in a wide variety of systems from simple to bleeding edge, impressing in all. A blow out best seller and demo examples are available in USA and Singapore.
For the XLR iteration, I have found the Oyaide Focus plug to be a more compelling proposition than the silver plated Bocchino, which simply didn’t show the same gains that this brand enjoys elsewhere in my product range. I will revisit this subject when I am able to procure platinum plated samples from Bocchino given how spectacularly well they work on the rca cable.
