Twisted pair - WikipediaAre all CAT5 and CAT6 cables unshielded or does one have to carefully shop for them?
It should mention "UTP" on the cable
The AWG number as well (22 is thicker copper as is 24 etc.)
Blue Jeans Cable here in Seattle build unshielded cables, bench test them and send certification along with cable - prices are well within reason.Are all CAT5 and CAT6 cables unshielded or does one have to carefully shop for them?
Silly me thought it meant Un-Twisted Pair lol.Indeed, UTP for Unshielded Twisted Pair.
Most "high end" CAT cables are extensively shielded as this gives better performance in the field used...I'm currently using a Sablon Audio ethernet cable which has 'extensive shielding' so this is good to know.
That is equal to no shielding....the shielding is not tied to the connectors
Unfortunately not. You will have to connect at least one side to ground to have a shield of any kind.even a "floating shield" would provide some isolation from external radiation, right?
Maybe Taiko has an answer.... naturally any CAT cable can be tried just what for? It will only add to the confusion as differences can only be linked with grave difficulty as we do not know what errors to expect.For those confused by the too many choices of ethernet cables
While discussing networking (noise):
Our current recommendation is to use UNshielded CAT5 or CAT6 copper network cabling, we simply get the best results that way ourselves since the introduction of the new USB card. There is a solid explanation for it which I will share now.
There are 2 main modes of noise stemming from network usage:
1) Noise generated by network activity / processing
2) Noise transmitted over interconnects
Noise type 1) is dominant in Fiber connections due to a higher current draw of the SFP module which is an explanation for a benefit to creating a seperate subnet or vlan in this case as that reduces network activity on that subnet. As it's fiber there is no direct path for electrical noise as fiber is electrically non conductive.
Noise type 2) is dominant in copper connections, we have a very consistent network noise profile which is now rather insensitive to variations in network activity. This applies to a much lesser degree to Fiber which we have to configure differently to get to the level of Sound Quality we're after as a direct result of it's higher current draw. Now let's take a look at copper networking's sensitivity to noise type 2):
A 1Gb or higher Ethernet cable is made up of 4 pairs of signal carrying conductors, nowadays often surrounded by a shield. The signal carrying conductors (data pairs) are transformer decoupled, both common and differential mode, with their centertaps highpass filtered and referenced to ground (on both sides), usually with a corner frequency of about 1MHz. Typical schematic from Intel reference design documentation:
Solid engineering here which you should typically find in any switch, regardless of pricelevel.
Now let's discuss cable shields. Cable shields extend chassis shielding to include signal carrying conductors into the system shield, shielding them from external noise sources and/or reducing emissions. Now what happens if we apply this to our hifi-systems. To make this more visible I've created a quick MSPaint drawing:
It should be clear from this drawing that these cable shields can create a conductive path from any device on your network straight into your system. Therefor we propose to connect as follows:
This is accomplished by using an unshielded ethernet cable, which would be CAT5 or CAT6 as CAT7 and CAT8 are shielded by design.
I think fiber is great if all requirements are met ! So i would not worry unless Taiko has a different view on this...Does this also mean that an unshielded copper connection is the recommended way the network to the connect to the Extreme, and not Fibre (which I've been using all along)?
To where? unconnected ground / air ? Eddy currents? Please evaluate your finding. As without any technical proof i cannot be with you in this... and pointing to a product does not help here. The only "physical" connection the shield has is with the signal cables within the shield (the ones you want to protect from noise) So all the noise that hits the shield will now be distributed over all cables within that shield unless it is grounded...A shield left unconnected on both ends will still attenuate higher-frequency signals because of the low-pass filter formed by its resistance, distributed shunt capacitance, and series inductance.
I have always connected to the Extreme by an UTP copper connection and have no desires to try anything elseDoes this also mean that an unshielded copper connection is the recommended way the network to the connect to the Extreme, and not Fibre (which I've been using all along)?
How long of a run is yours, Steve?FWIW, this is what I use. Made here in the USA by one of our members
“Freedom” Ethernet Cable | Triode Wire Labs
triodewirelabs.com
