What turntables do you use? Pictures would be nice as well :-)
Reactions: gleeds
TT: J. Sikora Standard Max Turntable
Tonearms: 2 x J. Sikora KV12 Kevlar Tonearms
Carts: Airtight Opus1 and MSL Platinum Signature
Phono Stage: VAC Renaissance
27957071-A13D-4D01-9448-123E706DB3C6.jpeg12FE2C03-9F39-41AF-9DC4-B0920537358B.jpeg4521C6FB-2141-4783-9B92-A95DAC0EF88A.jpeg49B77F1F-2303-4EC4-99CD-783973D961FC.jpeg
Galibier Gavia table with Triplanar VII and Analog Instruments Siggwan arms.
EA8BFB43-1917-428B-95ED-92CBEC82565F.jpeg9231C6DE-20AA-4D66-9404-208B9C53D10B.jpeg3B8F2B91-3230-439C-A07B-BE52170C111A.jpeg
Reactions: Salectric
Does the 3012R outperform the simplicity II?
No. Not from what I have heard so far. Both are on the same table now, so in the future I can compare the same cart.
Cheers
Reactions: nickif
Cheers
In my system, other arms can sound better with Atlas.
Reactions: XV-1 and bonzo75
Cheers
Did you try with the Lyra?
SAT and AS Tang?
I have a suspicion J Carr never designed his Lyra's to go onto the somewhat flimsy SME headshell , let alone the 3012-R
SAT and AS Tang?
The SAT didn't work well on the AS when I heard it with GFS (sounded wrong) and iirc tang preferred it on SAT on techdas. It sounded great on Gian's SAEC so Tang later bought that arm and think it sounded good on it. Jcarr used it with fr64 till he moved to SAT
Reactions: DetroitVinylRob
Yea, Jonathon designs his carts for the headshell to dissipate most of the energy from the cartridge - flimsy headshell/tonearms need not apply.
no such thing as best, as synergy plays such an important part - even if one does not know why the synergy is even there :p
dynavector XV-1s sounded really good when I had the 3012-R on the TW - no idea why.
