Pretty. Is that brush for the dust or painting?
That’s the Siberian squirrel hair brush supplied by DaVa for cleaning.Pretty. Is that brush for the dust or painting?
Very nice.
Although I have never had the pleasure of hearing the Gavia, I've heard nothing but wonderful things about it and I think the world of Thom. He is definitely a "class act" in the audio community and we are blessed to have himGalibier Gavia table with Triplanar VII and Analog Instruments Siggwan arms.
View attachment 86479 View attachment 86480 View attachment 86482
Great looking set up! I bet it gives you hours of enjoyment!TT: J. Sikora Standard Max Turntable
Tonearms: 2 x J. Sikora KV12 Kevlar Tonearms
Carts: Airtight Opus1 and MSL Platinum Signature
Phono Stage: VAC Renaissance
View attachment 86464 View attachment 86466 View attachment 86467 View attachment 86468
Whats the arm wiring ?
Does the 3012R outperform the simplicity II?
In my system, other arms can sound better with Atlas.No. Not from what I have heard so far. Both are on the same table now, so in the future I can compare the same cart.
Cheers
Cheers
Stunning congratulations.TT: J. Sikora Standard Max Turntable
The tonearm cable is Audio Tekne and the wire wrapped around the arm tube is for the Dava field coil power supply.Whats the arm wiring ?
Did you try with the Lyra?
The SAT didn't work well on the AS when I heard it with GFS (sounded wrong) and iirc tang preferred it on SAT on techdas. It sounded great on Gian's SAEC so Tang later bought that arm and think it sounded good on it. Jcarr used it with fr64 till he moved to SATSAT and AS Tang?
I have a suspicion J Carr never designed his Lyra's to go onto the somewhat flimsy SME headshell , let alone the 3012-R
