Valin likes it.
JL Audio E-Sub e110 Subwoofer - The Absolute Sound
JL Audio E-Sub e110 Subwoofer -www.theabsolutesound.com
Hi Shane,
I'm not a sub-woofer knowledgeable guy. I just thought it was cool you were adding them to your Maxx 3s so I went to read about them.
Trentemøller !
What if the reason you are thinking about adding a sub is really due to an LF weakness in the very amp that is now running mains and sub?
Also, REL's old canard about high level sub connections being valuable to preserve the system/amp tonality is part of that crap-shoot. Whatever tonality we perceive of a sub's contributions is determined by the harmonics which are still provided by the main speaker.
The former, of course, but it might also be the result of a common but noxious low frequency EDPR in the speaker. But, so what? Why not just avoid the speaker-level connection, if possible?This is theoretically possible.
But which do you think is more likely at 20Hz: naturally declining output from a loudspeaker, or a weird dip in amplifier output?
I am a fan of the CR-1 Active Subwoofer Crossover because its controls are very effective but it's subwoofer output is not being supplied from a post-power-amplifier source. Using it to add bass support under the LF output of main speakers running without any HP is feasible but such control is not common.If running a full range signal through a JL Audio electronic crossover is anathema, why isn’t the REL method of high-level speaker connection, and bringing the subwoofer separately up underneath the low frequency output of the full range speakers, a reasonable methodology for you?
Of course, using a HP filter for the main system can have other benefits such as allowing higher output/headroom from the main amp and speaker.
“”but it's subwoofer output is not being supplied from a post-power-amplifier source”” - well - that is problem! Have you ever heard REL?I am a fan of the CR-1 Active Subwoofer Crossover because its controls are very effective but it's subwoofer output is not being supplied from a post-power-amplifier source. Using it to add bass support under the LF output of main speakers running without any HP is feasible but such control is not common.
I’m not surprised at all. I have been using a pair of REL G1 with my Rockport Avior since 2015. Despite the real estate they occupy, I just can’t conceive listening without them. Now, admittedly, I haven’t tried the puritanical line level connection with an external crossover splitting the frequencies. Nevertheless, I can say with conviction ( for me) that the RELs made the most profound positive impact to the overall SQ......and as people would know here, the Aviors are not slouches in the bass department.I recently added a 2nd REL212SE subwoofer to my system.
Got them both used at decent pricing compared to buying new.
Added Morrow upgraded high-level cables, EVP footers, and high end power cords.
I love the extra bottom end they add, but they also seem to extend the whole frequency range of my MBL101E's and integrate superbly.
Think I am set for a lonngggg time!
Only at shows but, even there, I have found them not to be to my taste. To be clear, I believe this to be due to how they are integrated (and into what they were integrated) and not to the fundamental quality of the devices themselves. To be even more clear, I'd like to see them set up and measured(!) in a real setup.“”but it's subwoofer output is not being supplied from a post-power-amplifier source”” - well - that is problem! Have you ever heard REL?
And, fwiw, I am skeptical about accepting such individual, non-blind and non-statistical judgements, including my own.So yes, the high level connection might well go against conventional wisdom, but I can’t fault what I am hearing!
You are spot on here. Bravo"saying one component is better than another is a primitive way of looking at audio". They are different enough that they will appeal to different people.
Oh absolutely! I thought it was clear that I was speaking for myself....Only at shows but, even there, I have found them not to be to my taste. To be clear, I believe this to be due to how they are integrated (and into what they were integrated) and not to the fundamental quality of the devices themselves. To be even more clear, I'd like to see them set up and measured(!) in a real setup.
