Repair update: IO back to life after six months. Over the first 10 hours without any problem.
Almost forgat how good this phono is.
The first time I heard the Io Signature in my system, it was a transformative moment in what I heard. The Io presented to me nothing but musical bliss and excellent reproduction of delicate that just mesmerized me. In my experience over the nearly 18 years of ownership is that the V1/V2 seem to be prone to tube issues…tube whistle mostly for me. I know A few Io owners that live with the factory tubes because of the steps that Aesthetix takes to match and get the sound right in the Io before it ships. Truly, it is a hands on approach to delivering a great product. I am sill waiting for the house to be ready for move in, so it will be a few months before I get things setup again. Enjoy listening.Had an opportunity to meet Jim at an event in Stockholm earlier this week and also had dinner with him. He is an absolute wonderful person! Very interesting to hear about his history and design philosophy. We did listen to both Rhea and Io: same natural sonic cloth whith the Io having higher resolution and more space. It made me humble about tube rolling when I understood how they test tubes at the factory. I ordered an Io Eclipse in black with single ps and one input. My Ypsilion VPS-100 will see service in my second system.
I did some measurements while repaired the IO. The plate voltage on EL34 Is next to 750 Volt DC. The KT66 Absolute maximum plate voltage is 550v. So Kt66 can easily destroy the power supply if it goes to short circuit. It depends only on the tubes isolation resistance. Some kt66 can handle some not....
Ho fatto alcune misurazioni mentre riparavo l'IO. La tensione di targa su EL34 è prossima a 750 Volt DC. La tensione massima della piastra KT66 Absolute è 550v. Quindi Kt66 può facilmente distruggere l'alimentatore se va in cortocircuito. Dipende solo dalla resistenza di isolamento dei tubi. Alcuni kt66 possono gestire altri no....
Hello Massimo66Carissimo pet525Tt, anch'io ho avuto il tuo stesso problema e da tempo ho fatto riparare la mia amata signature dall'ingegner Alberto Ingoglia della Aurion audio, si è verificato un disastro all'interno dell'alimentatore, ma non avendo gli schemi ed i valori dei componenti non è possibile ripararlo, ovviamente ho scritto ad aesthetix ma sembra che mantengano i loro segreti più gelosamente custoditi del segreto di stato sull'assassinio di Kennedy. Tanta era la voglia di tornare ad ascoltare i miei amati dischi in vinile che ho comprato una allnic h7000v. Mi date una mano, sono anche in Europa e in particolare in Italia e non ho voglia di spedire tutto negli Stati Uniti perché oltre al costo della spedizione, visto il notevole peso che si avvicinerebbe al mille euro andata e ritorno,
Carissimo pet525Tt anche io ho avuto il tuo stesso problema ed ho da molto tempo il mio amato io signature a riparare dall'ingegner Alberto Ingoglia di Aurion audio, all'interno dell'alimentatore è avvenuto un disastro, ma non disponendo degli schemi e dei valori dei componenti non è possibile ripararlo, ovviamente ho scritto ad aesthetix ma sembra che tengano custoditi i loro segreti più gelosamente del segreto di stato sull’omicidio di Kennedy. Tanto è stato il desiderio di tornare ad ascoltare i miei adorati dischi in vinile che ho comprato un allnic h7000v. Puoi darmi una mano, anche io sono in Europa ed in particolare in Italia e non ho nessuna voglia di spedire il tutto negli Stati Uniti poiché oltre al costo della spedizione visto il notevole peso che tra andata e ritorno sfiorerebbe i mille euro circa, corro il rischio che al ritorno la dogana mi applichi una tassa pari al valore dell’Io signature(è già successo ad un mio conoscente che prima ha dovuto pagare è che dopo due anni è riuscito a farsi restituire la tassa doganale), tanto vale che con gli stessi soldi mi ci comprerei una cartridge koetsu red signature.
Kt77 is suitable to hande 800v anode voltage.Hi pet525TT, FWIW, while I understand some members have success in using KT66 in the power supply, per my communication with Jim White, KT77 should be used instead.
Használtam a Google fordítót, és úgy t?nik, @Massimo66 panaszkodik, hogy az Aesthetix nem küldi el javításra a sémáit. Ez rossz hír a külföldi vásárlóknak. A 2-3 doboz Atlanti-óceánon való szállításának költsége az európai ügyfelek számára megfizethetetlen (egyszer megtettem). Nincs "megbízható" javítóintézet Európában?
Can you explain the exact problem with IO?I perfectly understand your apprehension about keeping a stove lit in the summer, think that for a few years besides the IO Signature I had a nice class A preamp and the PLInius 300 SA reference as final amplifier with whose warmth my friends and I, while listening music and we organized Shootings of various cables, we boiled water to cook spaghetti and accompanied good music with excellent food and a nice glass of Brunello di Montalcino. in these listening sessions At my house in Palermo the air conditioners with their gentle breath became the indispensable accessory for the expert audiophile. in those torrid days a handful of heroes faced Mahler's titan with their own ears certain that they could aspire to the Resurrection with the second symphony by the same author
Thank you for your interest Today I call my technician and have him explain in detail what happened Personally I wouldn't be able to do a clean weld anyway from memory I remember that one of the large capacitors that are to the right of the transformers has burst and then all series of diodes are separate it is one of the two EL 34 IT LIGHTED UP TO BURNING RE IN A FEW SECONDS. Grazie grazie grazieCan you explain the exact problem with
I am not entirely sure, but sometimes companies may ask you to demonstrate actual ownership and that you are a valid owner and ask for you to supply the serial number in order to be able to request a schematic. I have learned this through experience with other equipment I have owned over the years. I also established a relationship with dealers and the company so they knew I had the equipment and when issue presented itself, I could cut through the red tape. Get to know the dealer and the company that builds your stuff. Good luck.When I start to repair the IO I was wrote to Aesthetix for a schematics but never had answer or any info. And The IO is not an easy wiring.
