Thanks for the infoUnfortunatelly nope…
I always wanted to try 842 in Pacific but never did…
BTW - there are much better options then mentioned KT88
what do you think is the absolute best combo for this dac
Hi Simone, (far from Distinguished) LOL, my routine goes as follows (perhaps others do different). I listen to music everyday. If I know I'm doing some chores outside, I won't power the H up until I'm back in the house. Once back in the house I turn it on and it stays on until I am done listening for the day. I avoid multiple power on and off. From what I have gathered leaving the unit on is less detrimental on the tubes than multiple power cycles. I may take a sauna for 30-40 minutes and take a break from the music, I just leave the unit on until I resume listening. I hope this helps and finds you well...JohnDistinguished Horizon owners: do you leave the DAC always on, or - to save tubes life - you switch it on when listening only? In the latter case, what is the warm-up time to sound at its best?
Another thing I neglected to mention when ever I am away while the H is up, I Mute the amp, its a good habit to have...Distinguished Horizon owners: do you leave the DAC always on, or - to save tubes life - you switch it on when listening only? In the latter case, what is the warm-up time to sound at its best?
Im 100% tube system except for my Extreme. I agree with you about the power on and off is when failures mostly occur but the tubes I use are very old and very unobtainium so I turn my system on every day half hour before I listen and always turn off my system when Im done. its tubes so the mantra is always "amps are last on and first off". Having said that each morning and evening I close my eyes and say a little prayer when the power switches are powered on or off.Hi Simone, (far from Distinguished) LOL, my routine goes as follows (perhaps others do different). I listen to music everyday. If I know I'm doing some chores outside, I won't power the H up until I'm back in the house. Once back in the house I turn it on and it stays on until I am done listening for the day. I avoid multiple power on and off. From what I have gathered leaving the unit on is less detrimental on the tubes than multiple power cycles. I may take a sauna for 30-40 minutes and take a break from the music, I just leave the unit on until I resume listening. I hope this helps and finds you well...John
This is also a very good protocol...I avoid turning on my Horizon unless I have a 3 - 5 hour listening window and I don't leave it on over night for the same reasons mentioned by others. However, I find that it takes about an hour of play before it comes into its own fully.
Ray
Steve you bought pretty much all the tubes on the planet your safeIm 100% tube system except for my Extreme. I agree with you about the power on and off is when failures mostly occur but the tubes I use are very old and very unobtainium so I turn my system on every day half hour before I listen and always turn off my system when Im done. its tubes so the mantra is always "amps are last on and first off". Having said that each morning and evening I close my eyes and say a little prayer when the power switches are powered on or off.
I did have a fun 6 months of exploring the world of very old tubes and their sonic characteristics. I’m totally chill where I am now. I have sufficient backups to the tubes I use and have sold off mint versions of tubes I ruled out. So all good RodneySteve you bought pretty much all the tubes on the planet your safe
Tube life extinction comes from the on/off cycling more than leaving it on. If you feel it’s safe enough, then leave it on continuously unless you know you won’t use for 3 days or more. Each on/off cycle introduces a molecule of air into the vacuum which eventually causes tube failure, that is how I was educated.Largely the same approach here. Turn on once a day, unless I know my return to the system is in doubt. I'll add it sounds 95% within 5 minutes. 15 minutes for 99%. However, if you leave the H on overnight, it sounds even better the next day. For me there is some personal stress involved in doing this, consuming the precious tubes, but the tubes are probably less stressed than I am.
I power down my tube amp if I'm away for over 15 minutes.
Yep, Uber safe! Steve, read your messages pleaseI did have a fun 6 months of exploring the world of very old tubes and their sonic characteristics. I’m totally chill where I am now. I have sufficient backups to the tubes I use and have sold off mint versions of tubes I ruled out. So all good Rodney
