Don and I thought we had a noisy tube in the Io. It turned out to be a problem with single-ended interconnect.
Now that the Io case is open, should I try replacing the four V1 and V2 tubes with NOS Telefunkens or NOS Amperex?
What are the sonic pros and cons of Telefunkens or Amperex, and each of them versus the already quiet stock tubes?
The system is already plenty transparent, and I don't want to do anything that would add brightness or edginess. Should I put back in the quiet stock tubes (JJ I think)? Or should I put in the Telefunkens or Amperex?
(I appreciate that ideally I would experiment with everything, but I don't have the patience for that right now. So some tubes have to go back into V1 and V2 in the Io. Which tubes should I put in?)
