I have tried multiple LAN isolators
Ifi v1 and new ifi , acoustic revive ,
At the end I liked this one the most , it’s under 300USD ,
https://www.sellarz.com/goods/view?no=107
I got it from EBay , this is final filter before entering Grimm MU2 .
Money aside, what led you to like the Sellarz?
Follow up: In looking at the eBay Sellarz site, there are two LAN isolators -- both passive it appears -- so I asked about the differences. Below are the replies:
LNF-10G: 10Gbps LAN Noise Filter for Music Server, Eliminate Transmission Noise ($198)
LNF-10GuM: 10Gbps LAN Noise Filter for Audio(10Gbps Isolator, Mu Metal Shield) ($253)
(https://www.ebay.com/str/sellarzelectronics?_trksid=p4429486.m3561.l170197)
"The LNF-10G's enclosure is made of ABS plastic, making it less susceptible to external physical impact than the LNF-10GuM, which is made of aluminum. However, the voltage characteristics of the material become the external insulation withstand voltage characteristics of the LAN filter.
LNF-10GuM is insulated with two layers (1 mil x 2) of Kapton Tape and has a theoretical insulation voltage of about 15kV (7.5kV x 2), but the enclosure of LNF-10G is made of 2 mm thick ABS material and has an external insulation voltage of min. 15.7 kV/mm x 2 = 31.4 kV(max. 34 kV/mm x 2 = 68kV)
Therefore, it [LNF-10G] is recommended to be installed in places where high insulation voltage is required. And considering that one of the functions of LAN Filter is “Isolation,” LNF-10G has an advantage in this very important function over other LAN filters. For reference, although you can't see it in the product photos, the LNF-10G is finished on the outside with very thick clear heat-shrink tubing."
[Also about the LNF-10GuM]:
"We usually call it electromagnetism, but this is actually a concept that combines electric and magnetic fields, and they should actually be distinguished. The metals with high conductivity, such as silver and copper, shield electric fields but not magnetic fields. Such metals are very transparent to magnetic fields. For shielding magnetic fields, ferromagnetic metals such as nickel or iron, especially high-permeability metals such as Mu-metals, are excellent for shielding magnetic fields.
Therefore, LNF-10GuM is used to prevent signals from being distorted by magnetic fields when there are devices or components that generate strong magnetic fields very close by."
