American Sound AS-2000 Installations- Far East (Tango)
Short answer, the additional width smooths out mid and upper frequencies. With this type of design you have both electronic and mechanical crossover, ie the horn and the baffle. Klangfilm‘s design is for 2m x 2m but due to space constraints we made them 1.80m x 2m so I added the slide out wings in case he has more room, it makes a difference even if they’re not fully extended. Staggering them is an aesthetic element, easier to make them flat but having wings hang out flush from the sides without the base section looked like an after thought.
david
I was expecting the bass response to improve with the increased width. Did you notice and/or measure anything in the bass response?
Congratulations on great speakers! Should we believe that audiophiles born in 1957 have natural ears?
I think it can be presumed that the designers of these speakers back then and as modified today have the ability to recognize natural sound with their ears.
It is decisions like these that make me reflect on the state of the industry and the performance being delivered.
Tang is still young. To state that these are the final destination is significant.
I have been reading portions of this thread and enjoying the discussion about the AS table and hearing the enthusiasm of Tang and others describing their arms and cartridges. However the photo of Tang’s table with 4 arms and lots of accessories on the turntable platform gives me pause. If I may be so bold, let me share several observations from my experience with a Galibier Gavia table.
1. The Galibier base allows for two arms each bolted securely to the base via an articulating armboard, similar to the AS although less elegant and less convenient. Unfortunately each time I added a second armboard, the sound quality of the first arm suffered slightly. This was true even if the second armboard was empty, i.e. no arm was attached to it. In my case, the flexibility of having two arms set up and ready to go was not worth the sacrifice in sound quality so I now have just one arm set up at a time. The AS table is no doubt better damped than my Galibier so the presence of multiple armboards and multiple arms may not be as much of a problem, but I suspect there will still be a difference compared to a single arm and once heard small differences often become hard to overlook.
2. A few years back, Thom Mackris came up with a revised tonearm mounting arrangement. He moved from a single bolt articulating armboard to a more massive 2-bolt armboard. With my 9 inch Triplanar VII the 2-bolt armboard was a distinct improvement. This surprised me because the 1-bolt armboard was secured with a large steel bolt and was seemingly quite rigid. Perhaps the greater mass of the 2-bolt armboard was responsible for the change in sound. In any event, my experience with the 1-bolt armboards on my Galibier makes me wonder about the similar 1-bolt armboards on the AS.
3. Lastly I have noticed that objects resting on my turntable platform also affect the sound. A digital scale and an Allen wrench were the items where I first noticed this. As a result I now keep only a tiny stylus brush on the platform. Again Tang’s AS table and the platform it is resting on may be less affected by such things, but I suspect there will still be some difference. It’s certainly deserves some experimentation.
Thank you for sharing your experience.
1) I have played with probably every switches of arm mount in all four corners. One arm. Two arms. Three arms. All four arms. Switching cart from one corner to another and another and another. Happens to have 4 identical arms to hear the same cart in all four corners too. But Of course not with intention to see if sound changes as you experienced in from your tt. No sound difference between four arm posts like yours. And no difference when there is only one arm on the table or two or three or four. Ddk would cut his finger to punish himself if such difference occurs on his tt.
2) I have never tried two bolts on an arm clamp of AS2000 because I don't have one with two bolts. So I cannot comment on this.
3) Now that you triggered me to listen when tools are on and off table. It is about time I clean up my room my table. So I will try. But I likely hear no difference. My ears are not so sensitive..unlike normal audiophiles. Practicality is in my dna. I have amps on subs with four 16" woofers I still enjoy my sound very much.
Thank you very much Micro. Let's just say the guy who designed these speakers in the fifties has the same taste in listening music as ddk, Peter, Tima and I. We would like to call it natural sound. Shouldn't we be free to call it anyway we like. Your sound, the one that sounds natural to you or suit your personal preferences, is highly likely different from ours. I don't know what you call your type of sound. You never characterized it never described it. But You certainly can call it natural sound too I dont think any of us would mind or get irritated hearing. ;)
You better believe all of us were born with natural ears.
@Tango Thanks for sharing so much of your journey. From my view you have been quick to acquire so much experience, and even more importantly to hone in on your priorities. I for one will miss your stories and descriptions now you have reached a summit.
This calls for a survey, who's seeking for a natural vs unnatural sounds. LOL!
Wonder how many would describe their system unnatural?
I am happy that you have an open mind - I only dislike when people call the sound that does not fit their preference as "non natural " or "artificial" or use the word ambiguous meaning to support dogmatic claims like "digital is not natural" or "measurements suck" .
I have characterized the type of sound I enjoy in many posts since 2011 - including references to specific recordings people can find in my WBF information page. But surely using the typical stereo language ...
I was pleased about your reference to 1957 . It is a Porto Wine vintage year - if you ever come to my country I will surely offer you a bottle - and my birthyear.
This is an interesting reply. I understand you put some humor behind it.
Consider listening to a live concert then listening to a reproduction of it. I don't think it is helpful to say one is live and the other is dead.
I don't believe there are posts that say those things.
Reactions: ddk and PeterA
Congratulations to David for having the knowledge, experience and determination to bring these speakers to life! Congratulations to Tang for pursuing this hobby with unlimited passion!
In my Thai audio chat group, 100+ people in the group, I actually never heard a single person say the word "natural" describing sound on their own. They just don't use the word natural to describe great sound they hear. Unbelievable sound. Great great sound. Realistic sound. Epic sound. Heavenly sound, etc. But not once natural sound. Members here are quite similar but not the same extent. If the regulars did not make a big deal out of the term natural sound 90% or more will not use the word natural sound to describe what they hear anyway. They would use those terms used in popular magazine. Or just say gobsmacking, etc to describe their experience. And somehow those people who use the term natural sound I just don't hear them use the word gobsmack describing their experience. My observation is unless you bring up the word natural or unnatural, most audiophiles don't even think about natural or not hearing great attractive sound.
Reactions: ddk
Tang, do members of your Thai audio chat group
refer to a common reference? I think words like natural, realistic, believable, and convincing, all share a reference. They refer to something very specific, the actual sound of instruments being played. Words like gobsmacking, great great, epic, unbelievable, and heavenly have no reference and in my opinion convey less meaning. What they do share in common is a sense of exuberance and wonder at what is being heard. And that is great. I often think in those terms too, especially when something sounds incredible. The problem is they are not very helpful when writing about how something sounds in an audio forum.
Reactions: tima
Unfortunately no reference Peter. Good to their ears, however, whatever that is, is what they are after.
That makes a lot of sense now and explains the language they use. Nothing wrong with chasing a sound you love. I now wonder if there is a lot of turnover of gear in your group. You went through that phase, and I refer to your office as a kind of audio laboratory, especially when you had all the different turntables and tonearms and cartridges. You seem to have become settled with eyes laser focused on the target. I suspect your learning will continue though with these new speakers.
They like to compare gears. The focus is on sound difference from one gear to another. So they are very very good at identifying how sound change from one gear to another through videos. And then visit real system. The main objective is to up the system up the dynamic up the clarity up the quietness up the reverb up this up that. Their appreciation seem to be on sound rather than music. Listen to sound not really music. Tweaker from hell. 98% digital. So I have been hearing a lot of Wadax comparisons.
I like comparing gears too Peter. It is fun to explore the new talk of the town. Different sounds through different gears is imo the charm and magnet of this hobby. After going through this fun part of this hobby, I think at one point an audiophile will realize he needs to have a north star to constructing a system and accomplish something. We cannot just change gear not knowing before hand where we stand what our system lack what our system not lacking. Ask the question to ourself a lot if changing a particular gear will take us closer to the north star. The most important part is to find the north star and can describe what north star is like you did Peter. Otherwise it is no system building. It is just gear play.
Forgive me Peter, I am posting in your thread about natural sound and I have not heard your’s or ddk’s systems, so your ‘natural’ and my own understanding may be different (or, there is the possibility I’d hear yours and go “oh, yeah - that!”)
I had a visitor come to hear Diesis “Roma” recently. After he left I spent a good while just listening and enjoying. So I sent a little note to Giuseppe @ Diesis:
The French have a phrase “Je ne sais quoi“, are you familiar with this phrase? Is there an Italian phrase that is similar? I ask because I often describe Diesis have that missing element, a little “je ne sais quoi” that makes them very, very special.
But, I want to honor your Italian flavor, not bring in some frenchman!
Giuseppe’s response I thought worth sharing:
I understand French thinking, I have a family part living in Paris.
In Italy it has the same meaning,
saying : There is something that strikes us most without understanding what…
But the receptors in our brain have infallible qualities to make us capture an emotion even if hidden.
In the notes of the guarantee certificate we wrote these words:
(You will never stop falling in love with them) this is what happens to us even today, each interface will produce a different result but always with the Character we have impressed, Both with small tube amps and with large Solid State Amplifire the concreteness and focusing of the stage will always be granitic.
You have turned on a fuse inside our passion, we also need these feedback to continue our passion.
Thanks again, Bob
(Keep in mind Giuseppe speaks no english, so our correspondence is typically filtered through Google Translate.)
So we both (myself and Giuseppe) recognize this something special and unique, but we’re not using your term. Konstantinos from Pilium did say he designs with a goal of creating a ‘natural’ sounding amp. Tim and Tang had not previously used the term (much?) in their postings (that I have read).
Is it possible this ‘natural‘ sound is floating around out there in a good many instances? When you hear a another system now, does your ability to enjoy the music suffer if at first your ‘natural sound’ filter is unchecked?
May I join in to answer this question Bob. I listened to the most expensive system with Living Voice, double Kondo 300b but instead use the unobtainium 300A, AS2000 with Neumann DST. The sound was not accurate to what I would call natural sound but this system sound utterly pleasant. 100 out of 100 would enjoy the sound me included. So really there was not any suffering but full of enjoyment. Still I prefer my system which imo sounds more accurate and natural.
Reactions: PeterA and Bobvin
Tang, a great post… your comments about system building have been said before but surely are worth hearing again for many. I know I have, over the course of my time in this hobby going back many years, listened for “more” and “better” sound (sometimes even less, perhaps noise or haze or glare, etc) but not towards a final goal. Perhaps because I don’t care that much for classical music, or because so often even when I hear a small jazz ensemble some instrument is amplified I don’t have this “live, unamplified” baseline reference. But my brother was a luthier, so I’ve heard guitars and mandolins played in front of me across the kitchen table — even then I can’t say I’d been keen to hear differences in timbre my brother could hear knocking a raw board with his knuckle and saying it would make a good top or back for a guitar.
Maybe some are like me, we know great sound when we hear it but don’t have the refined hearing as a chef or oenophile has a discerning palate.
Reactions: bonzo75
(...) Ask the question to ourself a lot if changing a particular gear will take us closer to the north star. The most important part is to find the north star and can describe what north star is like you did Peter. Otherwise it is no system building. It is just gear play.
There are many ways of creating our north star in this hobby. And IMHO gear playing can move its position in the sky - and, most of it, the stars are driven by the music you listen. Otherwise we risk that the north star guides our music.
