Is MG 1 airbearing tonearm ut it will be replaced by tw 10.5 much better, I just didn't have a base ready for it yet. Was able to test and assemble quickly the turntable.so what is that arm bearing, if not an airbearing?
Why do you think that statement is not true?This sentence is ridiculous and not true!
"There is friction caused by the air under pressure on the surface of the base and the bottom of the platter."
I didn't say that it sounds worse. I don't like the effort of doing it properly. I always think of my teacher's saying: "If it's not easy to construct, you haven't thought it through."there is a captured air bearing, and an air float platter/plinth. two different approaches. my CS Port LFT1 uses a low pressure, low flow air float where the air pressure lifts then bleeds past the platter in a controlled way. i believe that the American Sound tt designs use a somewhat similar approach, but don't know the details as it's a secret handshake hush-hush kinda thing.
air bearing linear tracking tonearms also do the air float thing with air bleeding past the machined surfaces.
my Rockport Sirius III had a captured air bearing for the platter. sounded quite marvelous.
a poor Airtangent copy IMOIs MG 1 airbearing tonearm ut it will be replaced by tw 10.5 much better, I just didn't have a base ready for it yet. Was able to test and assemble quickly the turntable.
I am thinking aloud here, but would not friction act as a damper in the motor-belt-platter system? And some damping is positive to avoid peaking resonances.. So a very low friction may cause motor irregularities to easier transfer to the platter- only inertia acting and no damping- ?Doesn’t the stylus in the groove present a constant load for the motor, even if the bearing has extremely low friction? Perhaps those who are discussing breaking or constant load are talking about a greater force against which the motor must work.
Please don't use the term " the final solution ", you are German !For me it's not important how long the turntable spins, it's just a sign that it's well constructed.
Much more important is how consistently the energy from the drive acts on the turntable and helps it to achieve an absolutely stable speed.
There's no better way to do this than with a heavy turntable combined with a heavy flywheel. Once you've heard something like that, normal turntables are hard to bear(a little exaggerated).
You have to listen toall your LPs again, because there's a completely different stability to the sounds, whether it's piano or bass, for example.
It will be finished in the summer, when all the rotating parts will be powder-coated the same color, and will look nicer.for me the final solution.View attachment 143186
Please don't use the term " the final solution ", you are German !![]()
Ok..sorry the last turntable in my lifePlease don't use the term " the final solution ", you are German !![]()
lolPlease don't use the term " the final solution ", you are German !![]()
What voltage is the Revox motor running on ? Is it around 130 V ? Looks like about the same small size pulley i use on my Studer motor.For me it's not important how long the turntable spins, it's just a sign that it's well constructed.
Same motor here I wanted to try it out but it will take some time. First I have to build everything nicely.What voltage is the Revox motor running on ? Is it around 130 V ? Looks like about the same small size pulley i use on my Studer motor.
Yes i have been in contact with Ernst, his system is plug in for Studer machines, i am not a electrical wizard like you !Same motor here I wanted to try it out but it will take some time. First I have to build everything nicely.
With a sensor on the flywhell
Looks like really good ..I'm more like catweazle..hahaYes i have been in contact with Ernst, his system is plug in for Studer machines, i am not a electrical wizard like you !![]()
At no point do I remember saying all inexpensive tables are good and all expensive tables compared to all inexpensive tables are OCD. Are you trying to develop some strawman compares to prove AS 2000 is worth the money?
Yes they are. Your compare to Denon DP4SF didn’t change anything. Your are right value is determined by buyer, you should chat about your TT on Wadax and Varese forums as those source owners also rate the value of their toysYou were talking about expensive, turntables being jewelry and implying their owners had OCD.
