steve, mm?? don't you guys use inches!
1-2 mm, that is impressive. (and I suspected your buggers would be hard to move!) How do you use the laser?? what can that tell you.
Hi don, have never heard maggies, but the people that have them swear by them.
Not that I wanted this thread to particularly go in the direction of a survey on what ratio you have, but mine are setup diagonally within the room (a decware reference)..it worked for me.
What I am wondering is 'just how accurate CAN you be with a tape measure'?? At least two people, the tape can sag differently, the spot on the couch used as a reference can vary ever so slightly, yada yada. I mean we do it to one of two points (I think), to the limit of our measurement (tape example) or to the 'that should be sufficient' level, which includes the limit of measurement with the tape with the added layer of 'point of diminishing returns'.
(from recent comments thought I'd better make this clear steve, not directed at you specifically)..so we think we are accurate to 2mm say, how do we know?? How can we confirm?
What IS the sonic difference between 5mm and two mm?? How would we perceive that difference? For example, I doubt we'd say 'oh, the left is later than the right', but if it has a sonic consequence, how do we hear that consequence?
I'll fess up and say this all has to do with the imaging stuff I was going to post about, but have changed it to a more general curiosity thing, mostly to do with 'how do we know it is as accurate as we think it is', limits of the techniques used.
For example, toe in. For most it would be the final tweaking in this process?? With that, what do you use it to tune for? Don uses it to get the widest sweet spot he can, I imagine another might use it to get the sharpest focus of the centre image, I use it to get the most enveloping ambience I can...willing to sacrifice pinpoint imaging for that....BUT I now suspect it can be a final way to get the speakers equal distance to the listener??
We do the best we can with a tape measure, then by rotating around one spike we can fine tune the distance that way (even if this is being done unconsciously)???
One last thing don, fwiw I understand, but what is fwiwfm???
