Best audiophile switch
Hi Todd!
If you are able to recall, would you please compare for us your sonic impressions of the Ansuz versus the Reiki?
Was there any sense in which one was "warmer" more "full-bodied" or more "organic" than the other?
Which model of Ansuz Ethernet switch did you audition?
Hello Ron, I will try to answer your question and give a more general reply about switches.
It was the Ansuz D2. I preferred the Reiki Switch but the person did not want to spend the funds for something that was so close. However, as I mentioned, it really wasn't a switch to switch compare as he had an optical isolator and then the Muon Pro before the switches. I would have preferred a comparison without the other filters to see the real gap between the two switches.
I view switches as "noise buffers". Let's say the noise level coming through the router is 100. We would like the noise going into the streamer to be 0. The various switches have various abilities to remove noise. Switch A may remove 10 points of noise. Switch B may remove 30 points of noise. Switch C may remove 50 points of noise. We want to put the best switch right before the streamer. So if we have switch A and B we would want to put switch A and then switch B and we would have 40 points of noise removal. We also don't want noise to get into the streamer from the environment so it is best to use a shielded ethernet cable (especially between the last switch and the streamer). But if that ethernet cable has the shield connected at both ends then the shield just provides a low impedance path for the noise to go from the last switch into the streamer. So get an ethernet cable that only connects the shield at the switch end.
So to your point. Adding a switch before of after the etheregen will almost certainly be a good thing. But you have to assess if the new switch is better or worse than the ether regen to know where it belongs (before or after).
You asked about "warmth and body". To my ears noise always robs the music of body. I don't like the term warmth as in many cases it means "blur" and I don't want blur. So when you add a good switch you should perceive more body to the music. To use some of your vocabulary...The acoustic center of mass is lower.
I hope all of this rambling makes sense.
I agree.
I agree, unless your final switch is the EtherRegen, in which case a shield-tied cable is perfectly acceptable. An alternative solution would be to use a shielded cable with a LAN Isolator between the last switch and the endpoint.
Melco release S1 switch
Most of the time I prefer Japan companies when the price is equal
It is not a question of price it is a question of performance and value. I prefer European and North American companies.
@Ron Resnick
i will comment that when i added the Reiki switch/LPS and Reku Network cable ahead of my Nordost QNet switch/LPS w/Sablon Ethernet cable, it did not warm up things; but it did lower noise and lower the sense of being processed, and added micro dynamics and propulsion to the music. all small things. adding these together the music was more vivid and alive, more analog. it lowered any tendency toward flat or bland. so it will take your dac/server more toward what it does. the network process is less an influence.
agree with Todd that added warmth would be a sticky wicket as it would be a coloration. other places better suited to pursue that. yet i respect that this is your hot button and are concerned not to push things the wrong way. best wishes with that.
Oh yeah...What Mike said. I can't believe I forgot one of the main things the Reiki does. Dynamic drive and "propulsion". PRAT.
I dont believe that noise removal should change the character of the sound. If it is "warmer" or "harsher' these are terms of coloration or distortions.
WHen one removes noise there is just more of the music and more of the space with the music and between the musical players. This is one of those you dont know you what you didnt know until you know times
That is a good way of explaining it. I also hear a greater ease in the flow of the music as if there was a slight pinch point previously. And then there are the qualities that are easy to hear without analytical listening and yet are very hard to describe. Like hearing further into the subtle interplay of musicians, which in turn encourages a more holistic listening attitude.
My current experiment places the switch in a different room from the audio gear, a different electrical circuit and before the passive filter which is positioned just before the streamer/DAC (MU2). I suppose the only way to test the theory of "closer is better" is to try that option. In my case, that would place the switch close to the digital gear (I have found that distance between such gear is best) using the same conditioner as the rest of the gear (thus some potential for cross contamination even with a Shunyata). There are trade-offs there.
Agree with your earlier point that a combination of active switch(es) and passive filter(s) works very well.
Reactions: Pokey77
Yes; it totally makes sense. Thank you very much!
Has anyone experimented with placing a fancy audiophile ethernet switch in-line in front of or behind an EtherRegen?
I have been playing with various placements, power and connectors since purchasing EtherREGEN four years ago. Today, my preference is for a Finisar 1318 singlemode fiber transceiver into the ER from a Ubiquiti router, with the other "A" ports to a Roon NUC server, NAS and a double (cascaded) modified Cisco Meraki switch into my streamer via eno2 filter. -So, for me, the "fancy" two-Merakis-connected-by-Finisar-fiber switch sounds best AFTER UpTone's excellent ER.
BTW, ER "B" port serves a Meridian 218 endpoint in a secondary listening room connected with the original ENO filter.
Mike, listen to Acoustic Revive ethernet cables if you can.
thanks Amir, for the suggestion. however; i'm very happy and probably done for quite awhile regarding network tweaking concerns. but if that changes i'll consider those cables. for years i relied on Emile from Taiko to let me know when i should worry about changing my network stuff. but now i guess i just wait for the urge. and i don't expect that to happen again for a time......if ever. :rolleyes:
Reactions: NigelB and Amir
Please at least try ansuz dtc supreme >>>>D2/A3. I haven't tried Reiki, so I don't know their difference.
Reactions: J007B
The laser wavelength is 1310 nm. The second set of numbers have no discernible pattern that I can identify even when considering those pictured on eBay. I’m not sure it matters but maybe an answer can be gleaned from the product worksheet.
I was reading this thread last week and I got it in my head to try the SR Ethernet Switch UEF. A demo unit arrived this afternoon on loan from The Cable Co. I got it connected to my music server and powered up by 3 PM today. I sat down to listen at 7 PM. I don’t know if it needs a day or two to stabilize but I wanted to get at least a preview of how it might sound. I just finished my listening session at a little past 10 PM. I am emotionally exhausted but I want to get this down in print while the experience is still fresh. I hope for more listening time tomorrow night. I am currently using a LHY SW-8 and an English Electric Eight dedicated to the music server. The SR UEF Ethernet Switch is connected directly to the router and is dedicated to the music server. Remember the First Rule of Audio: Your system sounds great, until you hear something better.
I consider it a great night of listening when one song I hear gives me goosebumps. With my system it happens occasionally. Tonight, 5 songs gave me goosebumps and one song brought me to my knees. Three of these songs have given me goosebumps before in the past but it hasn’t happened in a while. Two songs did it for the first time tonight. The only difference- The SR Ethernet Switch UEF. Right away I heard better clarity in the bass. I think the bass is a weakness with digital- at least compared to my vinyl rig. As I upgrade my digital side I hear better bass. It gets cleaner and provides more detail. Tonight the bass sounded excellent. I could hear the skin of bass drums. Voices also had more clarity and the highs are creamier. That’s the best I can describe it. The most important factor is the emotional connection. Tonight was the most amazing musical experience I have had yet with my system. Do I think this SR Ethernet Switch UEF is worth it? Yeah, yeah I do. Looks like I’ll be ordering one.
I know some here in the threads have found some more expensive switches to perform even better. But life is short and I hit on something special for me, therefore I will not hesitate to go for it.
Congratulations. Interesting and great that it had that effect so quickly. If I remember correctly, it took two days for the demo to settle in and have the same effect in my setup. Whenever noise is eliminated, I first hear it in the bass. But, as you say, the SR switch is all about engagement with the music. It just does something very right. A new unit does take many hundreds of hours to sound like the demo does.
Did your demo unit include an RJ45 UEF Performance Enhancers?
Thats is my experience as well. As a matter of fact any time I tweak something on my server/player or network side I will first pay attention to the bass.
Well, I did it. I ordered the SR Ethernet Switch UEF with upgraded power cord. I also ordered two SR Ethernet UEF Performance Enhancers. I'm not sending the loaner switch back until I get my new switch. Still experiencing chills and tears with this switch inserted into my system.
I just received today these UEF Performance Enhancers, ref attached photo. I get the chance to evaluate them right away with the loaner switch. Nice. They certainly stepped things up a notch. Bass immediately got even clearer and just overall sound is better. Best I can describe is I played some of Norah Jones' older songs and it now feels so intimate, like I am sitting at a table in a bar just in front of her and her band.
I can't get anything else done.
