That’s exactly what I’m planning to do.You could have one TT with two or more arms for stereo and mono play back if physical space and or finances are limited !
Thanks and confirming that the D’Ag Momentum phono preamp does offer different EQ curvesAs far as my monophonic listening experience is concerned, I allow myself to suggest that to enjoy the true merits of an authentic monophonic listening on vinyl, not only LPs with monophonic grooves are obviously indispensable, but also the preamplifier with mono stage.
Monophonic LPs are the offspring of 78s, not in terms of the material of the records (shellac) or their rotation speed, but in terms of the multitude of equalization (EQ) curves employed in their production. Instead of using only one curve, as in the case of the R.I.I.A. for all stereophonic LPs, in the pre-stereo era each record company owned its own monophonic EQ curve. Thus, Mercury, Decca, Columbia, EMI, Atlantic, Verve, Blue Note - to name the names of the most prestigious labels - transferred, with their own EQ, the tape to the lacquer disc; and since each mono curve was different from each other, and all different from the then future R.I.A.A. Mono LP from Mercury or EMI. The sound would be unbalanced at the band extremes: unpleasant high notes and intrusive lows, to give just a few examples. It is for this reason that mono LPs with mono grooves should not be played through our prephonos today... unless they also offer mono curves. The 'MONO' button found on the various preamps is therefore useless: it only couples the two stereo channels together and always with the stereophonic curve EQ (R.I.A.A). In other words: FAKE MONO! So, the first step is to look for a preamp that offers the main monophonic curves in order to access the correct listening to a greater number of LPs with mono grooves.
Also, note that mono cartridges don't all have the same load impedance.It is therefore very important to choose a pre that respects the technical characteristics of the cartridge. It is an important point and absolutely to be checked before any purchase. Some connoisseurs might disagree with me, but I think it's more important to focus on correct cartridge impedance matching to a pre that allows it, than to buy a pre top that doesn't offer the mono curve required by the cartridge. Do not under-evaluate this element, that matching is essential for correct listening.
I guess you forgot to add a one channel amplifier and a single speaker to the list IOT totally eliminate “FAKE MONO” situation.As far as my monophonic listening experience is concerned, I allow myself to suggest that to enjoy the true merits of an authentic monophonic listening on vinyl, not only LPs with monophonic grooves are obviously indispensable, but also the preamplifier with mono stage.
My advice is not to spend all your money on a single turntable for several reasons. First, you need a turntable to play back mono records with a mono cartridge
ref post #35reading this thread and just wondering , that the
TechDAS AF3 Premium
is not mentioned.
Paired with a nice
Glanz MH-1200S
tonearm and a matching cartridge, like Phasemation PP-2000, the given budget would be perfectly matched.
If I may enquire Why !!! What is the aim of such wanton gluttony.There is certainly a pleasure and attraction in a dedicated vintage Mono system. It seems more and more that serious guys are taking a keen interest in this direction. A friend (Some may know on here) with quite some experience in high end has been quietly amassing the finest collection of 301's and 401's...(He's using a push button 401 for STEREO)
For guys who are earnest and serious in terms of vintage Garrards, getting to grips with the various types of 301 and 401, living with them and appreciating what they can do and what makes them interesting makes a certain sense. Opinions not based on lived experience can often be a little 1D.If I may enquire Why !!! What is the aim of such wanton gluttony.
Garrard were the jewellers to the Queen and now the King of England.
They supplied the BBC and others hence curiosity about the deck lead me to collecting artifacts.
Motherwell and Rothko would approve of my chosen aesthetic.
Kindest regards,G.
Peter A,
Dear Sir you are partly to blame as the drool worthy bar you set aesthetically could not go unseen.
When I saw what I believe to be a very nubile you flanked by an extremely sophisticated mother?
I told myself that I would not be outdone by Boston's answer to "Dickie Greenleaf".
The subtle post may have been missed? Not by me, serving as a thorn the muse begat the answer. As such I have an ample supply of Garrard, open and closed fireplaces to return serve.
KIndest regards,G.
Thank you for allowing us the opportunity to collaborate with others in restoring your faith in audio, small manufacturers such as us with serious product lines always find it a mountain to climb to get this opportunity..Sir why buy one for fifty when one can have fifteen?
The 301/401 combo with the Elysium amps have revived my faith in audio and the people that do it properly.
The Z-Axis Symetrica power supply and cables have cemented that faith. Thank you all again.
Kindest regards,G.
