Steve
I don't know he Torus line-up that much but it seems that they are the same: The RM stands for Rack Mounted form factor and the CS for COmpact Size. THey are the same, different boxes.
The problem one has to keep in mind with AC power quality is that it varies from day to day even from mins to mins. You could well have measured it at a given time and found it to be very good. Same measurements next day and it is a whole different nut. To me filtering at that level is indispensable. I do not advocate balanced power but it seems to me that Torus has a good lineup of products. They even provide automatic voltage regulation in some places a necessity. If you can find a dealer that allows in home audition it would be wise to. Your room being in the building stage if you like what you hear you can then move to a more permanent, invisible and potentially better solution. They have models for up to 12 KVA and even more enough for to gotham and every other thingsin your system playing at full power for peace of mind they have even larger custom made models.
I would advise to give it an audition in your system. the worst is that you don't like it and return it. The upside depending on how clean your AC power truly is, can be substantial.
Hi Frantz
you and i had this conversation privately well over 1 year ago. Like you I am not an advocate of balanced power.
Any final decisions on my part will determined after room completion and some critical listening
