It is possible to build an all analog active loudspeaker. SGR Audio in Melbourne, Australia have been doing so for well over 20 years now.I agree that for people who swear by all analog components, an active speaker probably isn't a likely route.
Ultimately one day I want to try an active analog crossover and multi amps to each driver of my speaker. Sort of like Linkwitz speakers. But my assumption is, you applying a filter to the signal and what damage did that do. I would start out with full active until I figured out the specification. Then have someone make me an analog one.IME any manipulation, (digital or analog) to a full range signal risks and ultimately compromises quality. Pick your poison based on priorities and target market(s).
Why not? If you can make a truly full range active speaker that sounds better across every genre of music, whether that be streamed or from a phono preamp, for less than 100,000 AUD, I will buy it.Sure, I do however see zero point in doing so.
"Cheap amps with built in dsp" has nothing to do with benefits with active vs passive. You are making a poor strawman argument and attack the player instead of bringing serious arguments in to the discussion. Let's discuss the matter at hand instead.Being involved with speaker design is not an excuse for anything, seems like you cannot trow a rock in Scandinavia without hitting someone thinking they have cracked the code of designing the perfect speaker. Cheap amps with built in dsp everywhere seems to make these delusions of grandeur even more prevalent, diy people calling themselves manufacturers included. Meridian are still trying 30 years later, but most audiophiles are not buying that "perfect" speaker either. Good enough for the home theater, but not for a serious audiophile !![]()
A passive crossover network will generally lead to higher intermodulation distortion and put a veil with less detail and resolution over the sound. That's not high-fidelity.
You keep on talking about active versus passive. I don't like the sound of active digital speakers, active speakers with analog crossovers are definitely contenders for great sound, the digital versions not so much !"Cheap amps with built in dsp" has nothing to do with benefits with active vs passive. You are making a poor strawman argument and attack the player instead of bringing serious arguments in to the discussion. Let's discuss the matter at hand instead.
An active solution can of course involve external components. And very expensive amps for that matter, though price and quality here doesn't necessarily go hand in hand (we have repaired and up graded expensive gear FIR).
An external crossover with external amps is the better solution IMO, though internal can certainly work great if they measure well. But he best measuring components today are external, so that's what I would choose.
The result of Meridian alone doesn't tell us much about active vs passive. Same speaker with both options or same design as a start but with the options of deviations with extra freedom active gives, would be a right comparison.
you have answered your own question about where active digital crossovers belong. at the modest end of the marketplace. where development and build costs are more an issue. no one is claiming there is not a place for this technology. cost of building crossovers or the investment in it's design, are not relatively significant parts of a 'super' speaker. whereas at the other end of the price ranges it is.1. You will lose one of the main advantages of a digital crossover as a developer, the ability to quickly iterate and experiment. The development time and cost will skyrocket compared to a digital crossover.
you have a big hill to climb. good luck.As a natural outcome of this, the end result will not be as good.
the perspective of many of us is more nuanced than that. we are not 'anti'.....but we have to be convinced. not by words, but we would have to somehow experience it. our own logic says "analog sources + digital crossover + expensive speaker = not compatible. you would have to overcome that.It's not really about cost, it's about approaching it in a completely novel way, when you suddenly has the ability to do tens or even hundreds of iterations over a relatively small period of time. If during a listening session I hear something is off in some part of the frequency spectrum, I can experiment and adjust, and be back to listening in a few minutes.
The "super high-end" segment isn't really about better sound, it's about more expensive and exotic materials and design. This is of course completely fine, the experience of owning something exclusive and well built certainly holds value.
Beyond that; You and most others on this forum has concluded on this topic already. You have decided from the get go that digital has to be inferior to analog. You are only looking for confirmation that this is the case, not for evidence of the contrary. So there is little point in me engaging in rational discussion over this topic.
my own process if i was faced with my ears telling me that a great sounding speaker that i like a lot, has a digital crossover, would be first to ask a lot of questions. then maybe see if i could directly compare it to a known reference speaker i like with an analog crossover. you would need a system with top level analog sources to A/B it. that digital crossover speaker would have to really capture me to motivate me to investigate it. it would need offer me a value proposition to get me excited. that is a big ask.
but short of that sort of process, there will be a degree of dismissal in our reactions to this idea.
sometimes the market demands a certain particular product. other times something happens to open people up to a different direction. digital active crossovers in expensive top market speakers is simply not anything higher end buyers are looking for. but also, most do follow their ears. and so it's wholly on you to break through that reticence and demonstrate you have the better mouse trap.
it's on you to create that experience and buzz.
tell us where to hear it. hopefully in an analog source context. we will cheer you on in your efforts. but we need hear it.Sounds like we agree that I won't get anywhere by discussing it here then at least.![]()
once that happens there is more to talk about.
I would argue it's much lower than just the tip top, which is a fraction of a % of total available gear. As I see the current market, DSP is more mid - priced high - end equipment (I guess we'd need to equate to $ for better specificity, but the Sigberg speakers fit the bill) with a key attribute being Class D amps mounted in speakers for space and in many cases cost savings.it's more than the actual all analog components.
most very aspirational systems that get attention, are analog based. what pushes people to invest in a very high performance and high investment system?
seeing, or hearing, or reading about 2 channel music reproduction that excites them. right now that is analog based at the tip top. and gear most complimentary to it.
Don't agree at all.it's more than the actual all analog components.
You keep on talking about active versus passive. I don't like the sound of active digital speakers, active speakers with analog crossovers are definitely contenders for great sound, the digital versions not so much !![]()
Meridian, B&O, Holm Audio and Dynaudio. The Dynaudio might have been aktive analoge. None of them impressed me especially the treble did not compare to analog.Out of curiosity, which active digital speakers have you heard?
