I just received confirmation from my dealer (who has really been super accommodating through this process) that a pair of Atlantis XLR ground cables is on its way: I will compare these to the Atlantis RCAs that I am currently using in order to make a final choice of grounding cables for my line stage.
So, feedback would be very useful as to what should be the next step: Atlantis Tellus, Cleanus or grounding of additional components? I know that Chris (rockitman) decided to ground his amps using a second Silver Tellus, but this is not an option for me (unless I resort to chassis grounding), since my amps have only one input.
Also, I have a question regarding the Cleanus, although this might be too specific to my system. Power to my audio system goes through a subpanel with a 10kVA balanced transformer from which ten separate dedicated lines are run. Does anybody know if plugging the Cleanus in one line is likely to produce benefits for the equipment plugged in the other lines too? I would expect the benefits to extend to anything that is plugged in a power distributor on the same line, but I am not sure about other lines fed by the same transformer.
I'm still in the fog with regard to Cleanus. I was hoping it was a chassis grounding component like tripoint yet there is only one post for spade connections. I may consider the Atlantis box to boost capacity for the source components I have plugged into my one tellus. At some point I may disconnect the amp's tellus and determine if there is an immediate drop in fidelity. If not, I may try my amp's tellus in series with my source component tellus to see if there is more improvement. If so, then maybe that will be my time to try the Atlantis box with the source tellus box.
BTW, my understanding is that the single binding post on the Cleanus is for connecting to a Tellus, not for chassis grounding.
Re Cleanus, what I gather from the Entreq UK rep is that it acts as a highly sophisticated filter, but works on different principles to standard filters/conditioners/multiway sockets, being passive and in parallel w/the system (no components connected to it other than the mains distribution product chosen). So like S. Tellus, it doesn't get in the way of the signal. I believe by grounding it back to a Silver Tellus means that the Cleanus in effect grounds the mains product it feeds (in my case a Westwick 8kVA 10 socket balanced power transformer), and may replicate what the Troy does when you plug it's PC into the mains.
So, there is a benefit from just plugging in a Troy without any ground cables? Lloyd, can you comment on how significant is this effect relative to chassis grounding to the Troy?
Thanks, Lloyd.
Have you seen John's post 372?
So Cleanus plugged into a wall outlet, connected to a tellus is akin to a chassis ground setup like tripoint ?
In other words you would use spade to spade eartha cables connected to component chassis and tellus ?
Not according to the earlier posts by catcando, who uses a Cleanus in addition to chassis grounding.
Apparently, it is best not to mix signal and chassis grounding to the same Tellus. Catcando uses two separate units.
I am suggesting a Cleanus and dedicated tellus for chassis grounding...in affect doing what tripoint does...
That would be my understanding.
Cleanus is a passive power conditioner and I cannot recall reading anywhere of it being suitable for chassis grounding purposes and I guess you need advice from Entreq before going down that road.
Atlantis box boosts the effectiveness and capacity of up to two Silver Tellus and it serves those roles very well in my system.
