Informative blog from Lotus HiFi on Entreq applications, experiences.
http://www.lotus340r.net/blogs/entreq_blog.html
It would be interesting to get some first-hand impressions on the Cleanus. Hopefully, spirit will get his trial unit soon. At this point, I am leaning toward an Atlantis Tellus as my next step.
I can't help you with personal experience having had an Audience Aspect AR8 in my system for a few years and that does make a difference and is very helpful in serving also as a distribution block.
In considering the choice between the Cleanus and the Atlantis box you should take into account how good or bad your main's supply is.The limited no of reports I have heard re Cleanus over here have been in respect of people with problems over the quality of their mains supply, If yours is not a problem then I would guess that the Atlantis would be better and.of course, vice versa.
My mains is simply AWFUL, nominal voltage pre-balanced power varying +/- 10% to 15% every moment!!! No high end component can cope w.these swings. Down to only +/- 0.25% post-balanced power. Entreq grounding is the icing on the cake. I suspect Cleanus will complete the spell of balanced power-grounding synergy. I do feel inherently this is going to be more fruitful than just adding more grounding capacity via Atlantis Tellus.
That is the reason why I am leaning toward the Atlantis Tellus. Power to my system goes through a 10kVA balanced isolation transformer and other power conditioners that I have tried have proven to be ineffective. On the other hand, the principle on which the Cleanus operates might well be different from that of the conditioners I have tried.
Dan, I can't contribute to the physics of all this, but your contributions impart some light on what Entreq is trying to do, how it might help, and will hopefully pour cold water on the arch objectivist attitude that it's all a scam designed to prey on the naively affluent out there (are you reading this, Purite Keith?).
Despite my overwhelming positive experiences, I have had a couple of dead ends (grounding my prev Tom Evans Groove plus SRX phono stage, and trial on Atlantis add-on box). This proves a few things - as w/all things audio, YMMV - there may be electrical install design reasons as Devert has suggested that negate the effects of grounding - and that placebo/expectation bias is only a small part of the positive experience.
This is very simple stuff based on Ohm's Law.
Long before I'd put $15K into these boxes and cables, I'd hire an electrician with a ground resistance test meter to check my ground rod and measure the resistance on one of the Entreq boxes.
Has anyone measured the resistance on the $129. Eartha copper cable verses the $1639. Atlantis?
The standard length cables are only 1.65 meters long, do you think there's a big enought difference in resistance to justify the $1.5K difference in price? These are ground wires, not signal cables.
You can buy 24 AWG solid silver cotton insulated wire for $8.99/foot.
It's not magic.
Did your experience include an unsighted comparison, ie someone other than yourself connecting and disconnecting the unit?
Keith.
Keith.
L Hi, I would be fascinated if you could conduct a blind test, they only are only connected via a spare input on your preamp aren't they?
You wouldn't even have to disconnect anything from the mains, sit yourself down and ask someone to connect disconnect the boxes.
I take it that your equipment is already earthed through the mains, and you haven't disconnected the earth, which would be extremely foolish.
Keith.
I found one day the system did not seem right...a little off, but thought nothing of it. After a number of CDs i was irritated and thought it might be older tubes, or something...eventually discovered one of the spades in the back of the Troy had become loose and dislodged. As soon as i tightened everything up, better...within about 20 minutes, the system was back. Now i quickly check all my connections once a week.
