Sorry, but this makes no sense… You will spend more money (and you say cost is important to you), you will spend more time crimping on all these spades. You need to buy crimping tool also, and you will never get as good connections/sound, as direct soldering quality wire to the drivers.Yes, I see that. How likely is it that if we used quality after market spade connectors would there be a sound downgrade from point to point soldering? Or are we talking about splitting hairs here? Just curious, it would seem that upgrading the crossover and the internal wiring would make the most impact.
Adding a spade connector, most likely made of brass that is a poor conductor, between your quality cable, and the drivers is just stupid. Sorry to be direct.
And since you need to cable tie the cable to the driver baskets, as shown by both me and Markuzz, it will be quite difficult to use spades in the first place. You CAN NOT use thick/stiff wiring on these drivers without the stress-relieve from the wire being tied to the basket of the drivers. This because the lugs on the drivers are quite flimsy. If you go ahead and use spades + thick/stiff cable, and do not cable tie the cable to the driver baskets, you WILL DAMAGE the drivers beyond repair. The lugs will break, and so will the litz wire between lug and voice coil = driver ready for the trash can.
I have tried explaining this more than a few times now, hope it makes sense.
