What do you mean by piezo filtering? And how does Entreq accomplish that?....but they also add piezo filtering.
a quick definition for 'ground' is:: A common reference point.
I don't think that many of these boxes bond all the components to a common reference point.
a good solution would be a copper bus-bar terminal strip, with a flat copper braid to the chassis of each component.
bingo!
'Signal ground' ?
Keith.
Good engineering practice for grounding systems, both AC power and signal interconnects is well covered by experts like:
Keith Armstrong
Jim Brown
Ralph Morrison
Neal Muncy
Henry Ott
Bill Whitlock
Unfortunately it's Ralph Morrison that has the best system information. But little of his work is available on-line.
A good solution would be a copper bus-bar terminal strip, with a flat copper braid to the chassis of each component.
The graphs of with and without appear that they act something like a very inefficient version of a shield connected to one end of a cable for low frequencies. It's a guess still, but it appears that's how they work. The piezo material is presumably to stop them from being a huge RF antenna.
You simultaneously have vibration from the sound of the speakers. That will at least at lower frequencies also move the plates created a reverse polarity piezo effect. This will cancel out the music signal allowing the remaining noise to be absorbed by the magnetite.
What is a 'drain' and why would electricity be interested in it?
NB: the Entreq manufacturer says his device deals with 'high frequency' noise IIRC.
That seems a convoluted explanation. The sound coming from the speakers isn't a given variable as it depends where you install the box, room characteristics and so on.
You probably need to read this.
https://www.quora.com/What-is-geomagnetic-sight
I'll take a stab at this as Per appears not to be willing to divulge his secrets. If I get it wrong, well he can continue not to divulge his secrets.
You have the box, you have magnetite (maybe), you have flat plates, you have electric fields and not hard to imagine(emphasis on this word) the granular stuff is piezoelectric.
Okay, so noxious noise rides along the Eartha cable, into the plates in the box. The plates resonate with this noise, which squeezes the plates back and forth which squeezes the granules back and forth which is easily pictured as piezoelectric crystalline action. Spacing of the plates and etc (sorry redacted info here), are tuned for best effect. You simultaneously have vibration from the sound of the speakers. That will at least at lower frequencies also move the plates created a reverse polarity piezo effect. This will cancel out the music signal allowing the remaining noise to be absorbed by the magnetite. That is why sometimes the Entreq measurements show good effect at lower mains frequencies and less good at higher frequencies. The higher sound frequencies don't make it into the box to activate the plates ability to create piezo filtering to full effect. All makes plenty of sense.
It does, by trying not to absorb it.
As far as removing it from the system it would appear impossible.
No noise will go from the appliance to the box,.
and the appliances themselves don't radiate much in the RF spectrum.
Low frequencies are hard to absorb or block.
Have you listened to it in a way that allows you to say it isn't so?
According to PO, it does
YashN you're simply trolling at this point.
I'm not sure what "PO" stands for but no one on the face of this earth that knows much about electronics would ever believe noise goes to the box from the appliance. NO ONE. But please start calling every professor in the known world for electronics and try to get a different opinion.
