Thanks, but what´s about cartridge loading?Phono stage is an ARC Ref Phono 3SE. Arms are all 12” SME (V12, 312S) except on the Technics, where I use the 10” EPA 100. Cartridges vary, from a Koetsu Blue Onyx Platinum to a mono Miyajima Infinity Zero to the classic Shure vMR.
Don’t get me wrong. The Garrard is definitely a nostalgia trip. It sometimes takes a gentle push to get the platter moving (I use a VPI SDS synchro drive with the Garrard to reduce platter vibration by controlling input voltage). The Technics SP-10 in contrast comes to speed almost instantly. But it’s servo controlled. If you use one of the iPhone apps like RPM to check for speed stability, you notice a lot of sharp speed adjustments.
The Technics SP-10 MK 2 ist not servo controller but quartz controlled, what´s much more stable. iPhone apps are flimsy but if you recognize a lot of sharp speed adjustments there´s something wrong and the technics in the need of a proper service to get it back to specs. Same with the Garrard as long as the motor vibrates and needs to be pushed in order to start turning even with adjustage input voltage.
What plinth are you using with the Technics?
