Great..what headshell do you use for the kleos?Just a remind what I have done to modify for better match between cartridges and tonarm on my SL-1200G. Btw: Don’t forget the coffee while modify! Behold!
/ Jk
View attachment 115777View attachment 115778View attachment 115779View attachment 115780View attachment 115781View attachment 115782View attachment 115783View attachment 115784View attachment 115785View attachment 115786
Very cool, but for those out there looking for a simpler solution, google "Belldream Technics weights" - you get a set of 3 weights with the heaviest weighing 43gm!Just a remind what I have done to modify for better match between cartridges and tonarm on my SL-1200G. Btw: Don’t forget the coffee while modify! Behold!
/ Jk
I did use the Jelco HS-30, as I’m at work now I can’t give you the 100% correct details, but if I remember… -the total weight of the complete headshell, shims and cartridge was something like 33-35grams. About 6-8 grams more then the original SL-1200 can manage. Thus the extra external ”super counterweight”Great..what headshell do you use for the kleos?
How many mass do you add to the headshell?
Wow 43 grams… that sounds extremely heavy!Very cool, but for those out there looking for a simpler solution, google "Belldream Technics weights" - you get a set of 3 weights with the heaviest weighing 43gm!
Sorry, checked it up.. japp understand how you mean.. Well I guess that will work just fine…Very cool, but for those out there looking for a simpler solution, google "Belldream Technics weights" - you get a set of 3 weights with the heaviest weighing 43gm!
Hi Phil. The very experienced guy at my local shop has the same attitude. "I can make (pretty much) any cartridge work with any arm." I know so little about turntables, but suspect that that's right.Imo, unless one has an array of 5 tonearms (ranging from low mass, medium mass to high mass), and willing to do the painstaking job of replacing each with his specific TT and a Koetsu, that is the only time that we will know what tonearm 'excels' with a Koetsu, given that it is known as a low compliance cartridge. And that will presuppose too, that the high mass tonearm can work well with say, a suspension table like an Oracle or Linn LP12. To me it's too tedious to tell a customer to first find a 'suitable' or 'best' tonearm to match with his Koetsu. I haven't seen any dealer, Music Direct, AS, etc recommend any type of tonearm in their Koetsu shops. So I deal with whatever tonearm someone has and work on it. Worst case is the counterweight not being heavy enough or the Stone models. That is generally an easy solution. Johan had mentioned adding weight to head shells to add mass. So basically, we just say, let the Koetsu take care of things.![]()
No problems.Sorry, checked it up.. japp understand how you mean.. Well I guess that will work just fine…
Mine though… is constructed in such manner, that you have no problem to play any record with the cover on, even when the extra counterweight is mounted.
Other counterweights has the downside of touching the inside of the cover when closed, especially when the tonearm is close to the spindle. Maybe something to consider.
/ Jk
Consider this:Hi Phil. The very experienced guy at my local shop has the same attitude. "I can make (pretty much) any cartridge work with any arm." I know so little about turntables, but suspect that that's right.
As a follow up, I suppose I do wonder why if a manufacturer makes a beautiful carbon fibre low mass unipivot arm, I'd want to 'bastardize' it and add weights to the headshell . . . vs. picking a cartridge better matched to the arm. I'm still trying to wrap my head around that. It may just be that 'if that's the cartridge someone wants, they do it.' ??
Well doneNo problems.
The Belldream team have thought of that - even the biggest weight fits under the cover, even when closed. I coated mine in satin black to match the 1210 model.
Hi Bartolo,Hi Phil. The very experienced guy at my local shop has the same attitude. "I can make (pretty much) any cartridge work with any arm." I know so little about turntables, but suspect that that's right.
My Akito 3B is listed as 10g effective mass. So I have to correct myself in saying the ARO was an ultra light mass tonearm.I learned from Naim that the effective mass of my arm is 11 grams . . . for what that's worth!
So it appears the effective mass hasn't changed from what my "original" ARO is, at 11g. In post #1155 I had listed all the spec's that I have for the original ARO. I'm not sure if those have changed at all for the "new" ARO.I learned from Naim that the effective mass of my arm is 11 grams . . . for what that's worth!
Hi Michael,Please allow me to introduce myself:
Here are my two beloved ones:
View attachment 115850View attachment 115851
Greetings from Vienna
Michael
Welcome to this Koetsu lovers thread, krugdoktor.Please allow me to introduce myself:
Michael
ThanksHi Michael,
Nice pictures ! Welcome to WBF.
/ Jk
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
