We might not even like them. Lukasz favorite is the KR KT88 and that is what he is shipping with my Horizon.Yes but they will need several hundred hrs burn in to fully open up ?
They don't act as output tubes rather as workhorses to relieve the output tubes...Yes but they will need several hundred hrs burn in to fully open up ?
Can someone tell me who made this tube
There seems to be an M on the tube
Is that Mu?
This one also measures 84/84 and has gold prongs
Maybe there are some pre-amp/amp combinations that would perform better with the Lampi vol control bypassed? Or is it the general experience that using a good dac vol control (like Lampi's) dialed into the pre's gain will usually be advantageous?Yes. Otherwise why have one
If the 6900's are going to last as long as purported, maybe used is not a bad way to go. Even from a reputable dealer, how does one even know if a "NIB" has never been used?Ones on eBay are used. Mine are NIB
good point..The last set I purchased measured higher than most and the boxes looked as if they had never been opened. So I have 3 1/2 sets of the 6900 and if they prove to be a winner in my situation I feel I have more than enough to carry me through my life time. If they don't prove to be a winner I will likely sell some or all of themIf the 6900's are going to last as long as purported, maybe used is not a bad way to go. Even from a reputable dealer, how does one even know if a "NIB" has never been used?
I use the VC on my Lampi to dial in the tubes I use. My VC typically sits somewhere between -12Db to -16 Db I rarely change the Lampi volume control from these levelsMaybe there are some pre-amp/amp combinations that would perform better with the Lampi vol control bypassed? Or is it the general experience that using a good dac vol control (like Lampi's) dialed into the pre's gain will usually be advantageous?
After a year of running my Pacific with my Canary Audio C1800 Pre, I decided to try running the Pacific directly to my Amps. I was amazed at the results. I found the noise floor to go down and the clarity of my music to be slightly better. As a result, I am pretty sure I am going to sell my Pre and just go with the Horizon. This will be one of the items I talk to Lukasz about.I use the VC on my Lampi to dial in the tubes I use. My VC typically sits somewhere between -12Db to -16 Db I rarely change the Lampi volume control from these levels
(...) Even from a reputable dealer, how does one even know if a "NIB" has never been used?
Although I have 3 "measure as/better than NOS" UX112As blow in only a few weeks of use. So have given up on them.
Unless I just picked the wrong supplier?
A US based Ebay supplier. Don't want to name him here. I might have just been unlucky. I am in the UK in the MidlandsWhere did you get them and where are you located?
Hi Rau, can you refer me too a decent 46 tube brand and a source? I am getting Pacific balanced looking for a matched quad. Thanks!Try some 46 tubes if you have the chance, 200iq is on my short list , well long list now after Horizon purchase
