What is this Adagio volume control of which you speak?I just took out the shunt volume attanuator (dale resistors and a TX2575) and replaced it with the losless Adagio volume control, wow what a difference that makes!
A good while ago I compared volume attanuator solutions and the Khozmo sounded best (by far, including TVCs), this is next level transparent. three blind mice Tsuyoshi ..
Cees came up with a system changing the reference voltage for the R2R network to control the output volume, It's a motor driven potentiometer that controls the output volume, I never gave it much thought until I tried it earlier today...it works!What is this Adagio volume control of which you speak?
Sounds good, one little question what shunt resistors did you use Z-foil vishay?I just took out the shunt volume attanuator (dale resistors and a TX2575) and replaced it with the losless Adagio volume control, wow what a difference that makes!
Wow! Quite dynamic!I just took out the shunt volume attanuator (dale resistors and a TX2575) and replaced it with the losless Adagio volume control, wow what a difference that makes!
Vishay Z foil are IMO the same as texas instruments TX2575, yet those can be ordered to measure.Sounds good, one little question what shunt resistors did you use Z-foil vishay?
Hey Marcel, try "Speak Low," also by Tsuyoshi Yamamoto! Thanks for posting the vid. Sounds sweet. Nice.That recording is the best /most dynamic one for Piano I know!
The bass fiddle and piano have enough weight to sound "present". Balance is sweet too, very "natural" sound. I like the sound a lot, the looks ...ah.I just took out the shunt volume attanuator (dale resistors and a TX2575) and replaced it with the losless Adagio volume control, wow what a difference that makes!
those sound great with the right amp, yet they also show their age IMO...After 40 years, I've tried 'em all (well, not really all) but keep going back to my LS3/5As.
Not on an LS3/5A. If you think anything is better for reproducing the majority of the piano range (Bösendorfers excepted) then something is wrong elsewhere in your system.Piano sounds weird to me. Shrill.
Or foo foo exotic parts. Hard to know. Having to cover the wood makes me think they've been working backwards from some harsh sound they didn't like in the stereo.Yes a tad metallic. Closely miked?
As soon as I replace the delaminating plywood panel on the back of the right bass cabinet so it doesn’t buzz I will gladly do so.
Ok bonzo75, I was able to find one amongst my collection that you should be familiar with, just for you:Can you please post some classical videos?
