Modern speakers vs Vintage speakers
Very interesting!
I can attest to the massive difference an improved crossover can make.
Also use the Duelund 16 and 12GA tinned copper wires. They take a LONG time to break-in - 150 hours. The sound will change significantly during that time, including sounding downright terrible for the first 100 hours or so…
I am using a combination of 12GA and 16GA. Each sounds considerably different. At the low cost, it’s worth experimenting with both gauges.
Your speakers look fantastic!
Very interesting!
Wow... impressive speakers and XO's!
My findings regarding Duelund speaker cables align with yours. Once you get past 150-200 hours they sound wonderful. Great bang for the buck when it comes to cables.
Reactions: Zeotrope
Thanks guys!
I was ready to give up on the Duelund wire. They are really “that bad” until they are broken in. I couldn’t believe they would get better, thinking the differences had to be due to other factors. Also, according to Jeff Day, who’s tested these extensively, burn in devices don’t really work well. So the best option is to use them through the burn-in.
For those who are patient enough, they are outstanding, and at very reasonable cost.
I am having second thoughts regarding the super tweeters. I changed my compression drivers from ferrite 902-8B, to AlNiCo GPA 802-G8s and then ran two-driver, compression driver volume set at top right corner of the black base plate. I also removed much of the wool felt from the insides of the bass cabinet. Sounds good.
At the end of July I am hoping to get Kedar around for a listen with and without the super-tweeter engaged for his opinion (I suspect his high frequency hearing better than mine), and also swap a GM70 amplifier in place of my Ayon Spitfire for a listen. Will write about that when the time comes.
IME adding tweeters, or supertweeters can only be succesful if you take great care adjusting them for time coherence
Which GM70 amp?
Which GM70 amp?
the same one featured in the video with Bill’s pnoe and the living voice air scout (where I preferred it to the Kondo Neiro 2a3 when we used the copper valve)
Reactions: Rensselaer
Also planning to arrange for PX4 and PX25 at that time
weren´t they rather noisy?
No there was a hum which was resolved. They were voiced initially on universum which are 96 db and the pnoe are crazy db so that had to be adjusted. They are better than Kondo Neiro 2a3 and audio note empress 2a3. Will also compare them to Shindo 300b my gut says they are much better
the UK made GM-70 Bill talked about?
This one is not original Western field coil system but replica made in Japan.
But it sounds fast and go deeper.
I asked shop owner whether he can find me Western original field coil systems.
He need advance money and three months to find it.
Reactions: jbazz and je2a3
Magico M9 sounds like the best top grade whiskey with no faults at all.
But it is too heavy for my second floor listening room with wooden pillars.
On the other hand Western original or replica speaker sound like vintage wines.
They may not sound perfect but with peculiar flavor. :D
Reactions: MRJAZZ and Lagonda
Some of nice vintage speakers are also on sale.
we 555w system with original 16A, ks6368 horns....
LANSING 287 driver & X-overs, Power supply
westrex a-11 amplifier system
westrex 2080.2090 with horn system
westrex 753A speakers
western electric 757A speakers
neumann vms66 with cutting head, cutting amplifier system, manual, etc.,
TRANSFORMERS : we, peerless, utc, triad transformers
Thus I will try to audition them this weekend.
I will let my impression or video soon. ;)
crazy cool shop! Must have been a blast.
Reactions: thomask
