Here is what was sugested on another Topic. I just bought it From Amazon. It was cheaper.
“Hi, you need to buy the following as recommended by Emile
https://www.startech.com/Networking...abit-ethernet-fiber-card-open-sfp~PEX1000SFP2
Two of these:
https://planetechusa.com/product/mgb-tlx-mini-gbic-lx-module-20km/
and a LC-LC connector OS2 grade single mode fiber cable at the desired length.
Its pretty much plug and play and you need to load the cards driver on the EVO.
It’s simple to do and I received great support from Emile and his support team. Hope this helps all EVO owners.“
May I suggest a simple experiment which can illustrate how much a particular type of connection or interface is contributing.
My server is a windows box running jriver but other setups with memory playback can also be used.
It is actually very simple. Load a track or album in ram and disconnect the network. It should be disconnected both from the server and switch sides, so the ethernet cable can no longer radiate rf and the switch should also be powered down.
And voila, you are now listening under the conditions of the best ethernet cable and switch.
Even if you object to normally using jriver this will give you a clear idea of what improvement the perfect network can make.
To my ears, adding an ER change the sound dramatically while the M12 still retain the sense of a neutral sound.
I'm happy to answer any questions about the Rendu and Module series. For the record though we don't recommend any fixer upper gadgets before or after the Rendu. I know people do this and that fine, but the only thing that is necessary for great sound is a connection to your network and a connection to your USB DAC or digital converter.
Hi Bob,
If I am up to date with your various switch setup changes/upgrades over the last month, you are now running x2 M12 Gold.
Is the humble EdgeRouter in bypass mode still in your setup after the Verizon Router?
Geoff
It's hard to understand how the EdgeRouter improves on x2 M12 Gold's!
EdgeRouter as replacement for Verizon I can accept but....in series as a switch??
I am gob-smacked but I accept what you say as I don't have the resources to try.
Thanks for sharing.
G
Thanks for sharing.
G
Hi Bob,Geoff, thx you were the one, in a very nice way I might add, to get me to "jump off the diving board" into the deep water....thank you
Hi Bob,
Are you powering the Verizon router and fist M12 from the same Optimo LPS?
Maybe I missed it, but what are you powering the 2nd M12 that connects to the Extreme with?
Asking because I’m wondering if powering all 3 devices (Verizon router, 1st M12 and 2nd M12) with their own LPSs would produce a significant improvement since you wound isolate each device from noise bleeding into the other.
the M12 that connects directly to the Extreme should probably have its own LPS.
Hi Bob,
>>>YES.
>>>With the supplied small power supply. I can't power the second M12 until I get the second Optimo because I don't have the correct cable that goes from the second M12 switch to the Optimo.
And if you are still in the experimental mood, could you test the difference between one M12 vs two M12s now that you have taken the Edge router out of the equation.....asking for a friend ; )
