Now I'm confused too
Are you talking about the usb connection from the server to the dac? usb doesn't run on the input to the server side near switches. OR are you talking about an ethernet connection between the server and the dac?
I think we all thought that you were talking about a direct connection from the router to the input of the server, which would be connected directly with a LAN cable.
Specifically what connection are you referring to? If it's between the router and the server, it's not usb, right?
Just curious as to what connection you are talking about......thx
BTW, I thought you were referring to a direct connection from the router to the server via a lan cable. I think that we have all been there before we discovered the sonic uplifts that are gained by adding switches, LPSs and enhanced routers vs. ISP routers.
